17's and 18's for rims... show me your rims!
You know, de-chromed, big Porsche rims, Brembos, etc.,... German Look rules!
taozen
Post by taozen » Wed Jun 09, 2004 5:47 pm
17" 2001 Boxsters (this was the day after losing my engine so the back is a little light in this shot)...
1969bluebug
Post by 1969bluebug » Wed Jun 09, 2004 6:51 pm
that is one bad ass bug,
can you send me some pics
maj1@aiosolutions.com
thanks
1969bluebug
Post by 1969bluebug » Wed Jun 09, 2004 7:03 pm
found your site really nice car man your work into it shows good luck..
Kenny2428
Post by Kenny2428 » Wed Jun 09, 2004 8:21 pm
Whoa! Thats one sweet looking bug!!
PW4056
Post by PW4056 » Thu Jun 10, 2004 1:34 am
Those are Jeremie's. :D
Mikes72sb
Post by Mikes72sb » Sat Jun 12, 2004 8:02 am
17x7, 17x8.5 Porsche Boxster. 205-40-17, 245-45-17 NT-555 tires.
taozen
Post by taozen » Sat Jun 12, 2004 7:49 pm
thanks for the compliments guys. i am way overdue to take more quality pics, but keep waiting til i can get the engine back it so it sits better. there is quite a bit of info on the car on the VKG site and tons of build info as i went along on germanlook.com. i will have much more coming. engine should be back in in the next few weeks.
aceracer24
Post by aceracer24 » Mon Jun 14, 2004 6:16 am
Hmm I see alot of people running 17's on the car. I was skepitical about it at first. Here is what I have and if you have any info let me know what works.
75 beetle w/SWING AXLE, 3 inch wider rear fenders (what offset do I need in the back) stock front fenders, 2 inch lowered and 3 inch narrowed front beam.
Basically, I have some 17's on the back right now and running 235/45/17 (guessing rims are 9-10 wide but not sure) tires on them. The rim is ever so slightly wider then the tires are (laying down only rim touches). I had to put in a 1/4 inch spacer to keep the rim from hitting the bolt area of the rear where the body mounts up because I dropped the back about 2 inches. The rears slightly angle into the car but barely.
I tried putting this same size tire/rim on the front and have no clearance to turn. Rim or tire was hitting against the shock tower but right now I don't remember which if not both. So what I am looking for is advice on offset and rim/tire size. I really want to run 17's all the way around but no clue where to even begin.
If anyone has any advice please post. Thank you.
rae_sevilla
Post by rae_sevilla » Tue Jun 15, 2004 9:58 am
I have a Rota Toxxin 17x7.5 wheels on all four sides, modified strut using lancer '94 rear coil spring for neede clearance at front and my spacers are around 1 inch thick on all four sides, its a cheaper way to start a project using 17 inch wheels, even the fenders are stock.
Hope this gives some info. :)
aceracer24
Post by aceracer24 » Tue Jun 15, 2004 4:23 pm
Do you know the offset though? Thats what I really need is the correct offset or close to it. I can't try every tire/rim combo from the store till I find the right one :P
rae_sevilla
Post by rae_sevilla » Tue Jun 15, 2004 7:27 pm
corction on the width its a 17x7 not 7.5 sorry, and the offset is -42, 4x114 bolt pattern. :)
rae_sevilla
correction on the width its a 17x7 not 7.5 sorry, and the offset is -42, 4x114 bolt pattern. :)
aceracer24
Post by aceracer24 » Tue Jun 15, 2004 9:23 pm
Thx for the info, my only concern is that I have a balll joint front beam, differance is that it's dropped 4 inches (CB dropped spindles and 2 inch lowered beam) and narrowed 3. I'm wondering if -42 offset is enough. hmm, might just have to do some trial and error I guess.
yllwveedub
Post by yllwveedub » Thu Jun 17, 2004 6:52 pm
Sandeep,
how wide are those fenders? and how big are the spacers used to fit those cup wheels on the car? thanks
~Josh
Sandeep
Post by Sandeep » Fri Jun 18, 2004 8:43 am
Sandeep,
~Josh
2" wide front and rear, no spacers. 993 Biturbo conversion on the front and 930/944T conversion on the rear. Using factory Porsche parts means no spacers. Check www.germanlook.com for more info ... its all detailed there.
Sandeep
