Project "Racelook"
You know, de-chromed, big Porsche rims, Brembos, etc.,... German Look rules!
racelook
Project "Racelook"
Post by racelook » Thu May 12, 2005 9:05 am
So I thought I can better open an new thread for my bug. I'm restorating/building my 1303 S from 1974
I'm now more than 2,5 years bussy with this resto. This is how it stands now:
At this point the follow things are done:
Chassis:
-Every rust is out. Several pieces of framehead, napoleonhead self made, 2 new floorpans welded in. Two 12mm fuellines installed (what an work was that, but there in). I'm now at the point where I'm bending my 6mm RVS brakelines. (after that the chassis has to be maked clean to bare metal and will be sprayed with paint)
Body:
-Every rust is out (after many, many hours of welding).. maybe there's some little spots left, but they will be welded when I make the body clean to bare metal.
-Race-fuelfiller from Sparco is in. (also lots of work with the home made holder for it)
-After 2 pair of verry crap doors, finally got 2 good doors. Both of the doors are smoothed, so there are no doorhandles anymore. (will be opend eletric)
-The enginelid is changed for an lid of an 1300 (without vents in it). I've started with making an metal scoop on it (almost 3 months ago, but has not finished it).
-The Remmele side-airscoops are "in", everything is prepped for the installation, they only have to be glued in.
-An aluminium highwing is also from the beginning of this project in my property. CAD/CAM drawings for new wing"foots" are ready and waiting to be machined (laser cut).
-An full rollcage is made by our self, more details can be found in this topic:
http://www.shoptalkforums.com/viewtopic ... t=rollcage
-Hole the body is cleaned from inside and outside. Every hook is smoothed, every not functional hole is close.
-Eberspacher heatchanger lays ready
-Kamei-spoiler lays ready
-Engine and gearbox will be for this time only been cleaned and painted.
-Stripping the paint and all the body work has to be done.
I will update this topic as fast as I can.
Greetings Wiebrand
racelook
Post by racelook » Thu May 12, 2005 9:11 am
So my first update:
This are honestly just pics of about two weeks ago (when I had some time). I've been busy (so I said in above answer) with putting in two fuellines of 12mm (where originally sits 1 of 6mm) in. It was verry verry ****ty work, but hell yeah someone got to do it.
At first an pic on which the holes on the backside are good to see. Also are the tules en the cut out piece verry good to see to get the lines in.
An detailpic.
http://www.keversite.nl/fotoalbum/fotos ... 232611.jpg
To really get fuel from the front to the back they have to have an exit on the front.
http://www.keversite.nl/fotoalbum/fotos ... 232701.jpg
After thtat both sides where welded close.
-Backside
http://www.keversite.nl/fotoalbum/fotos ... 232741.jpg
-Frontside
http://www.keversite.nl/fotoalbum/fotos ... 232836.jpg
After a lot of "playing" with the Dremel I get this ending result.
-Backside
-Front
I think it looks verry nice, just like off fabrique
Wiebrand
Steve Arndt
Post by Steve Arndt » Thu May 12, 2005 10:31 am
Nice work!
coxy-ben
Post by coxy-ben » Thu May 12, 2005 3:37 pm
hi wiebrand !
what engine will you put in your VW ??
Benoît :D
racelook
Post by racelook » Thu May 12, 2005 3:54 pm
coxy-ben wrote:what engine will you put in your VW ??
:roll: Through money shortage the first time I will use the original engine (1600cc).
Wiebrand
junkyardoval
Post by junkyardoval » Sat May 14, 2005 7:38 am
Very nice work. Keep us informed with photos.
Ernie
coxy-ben
Post by coxy-ben » Sat May 14, 2005 8:12 am
Wiebrand
original 1600 ?? with a turbo ? :lol: :lol: :lol:
randyj
Post by randyj » Sat May 14, 2005 12:48 pm
Hello Wiebrand,
Your work looks great! Do you have pictures of how you tied down the lines inside the tunnel?
Thanks,
Randy
racelook
Post by racelook » Mon May 16, 2005 5:19 pm
Hi Randy.
No I don't have pics of the lines inside the tunnel. I've tried so photograf that but it was to dark so I couldn't get an good picture. But there is no extra tieding in the tunnel. The original tiedings are verry pain in the a$$ to get lose. And are on verry tight spots so I couldn't use them again. I've used some tyraps and that's all. The space for the tubes is verry tight (through the bigger size as the original ones) so the sit steddy. And through the rubber manchets in the front and back the lines sit verry good.
Wiebrand
racelook
Post by racelook » Mon May 16, 2005 5:32 pm
The strengthen gearboxrubbers I picked up last Friday at Franky's VW Service. I now only have to make an bracket to mount them on 8) .
Wiebrand
racelook
Post by racelook » Mon May 16, 2005 5:37 pm
So, the breaklines are finally in. It did go quite good, exactly the long tube was verry tiedy to bend by the HRC.
Back
http://www.keversite.nl/fotoalbum/fotos ... 233221.jpg
Front
http://www.keversite.nl/fotoalbum/fotos ... 233351.jpg
Goes quite nice!
Greetings Wiebrand Bunt
p.s. excuse for the green pictures.
racelook
Post by racelook » Sun May 29, 2005 4:56 pm
So guys it's time for an new update.
At first some clear pics of the install of the brakelines.
Back
http://www.keversite.nl/fotoalbum/fotos ... 224114.jpg
http://www.keversite.nl/fotoalbum/fotos ... 224159.jpg
Front
http://www.keversite.nl/fotoalbum/fotos ... 224301.jpg
Some steel and silence blocks for the transmission mid mount I'm gonna make.
Steel and other stuff collected to make my own Cup-strebe.
The packet that came from Topline.
http://www.keversite.nl/fotoalbum/fotos ... 224642.jpg
This was in;
http://www.keversite.nl/fotoalbum/fotos ... 224932.jpg
Everything out packet gives this;
Polyurethaan for al moving stuff for my chassis.
And today also begin with the making of the transmissionmount for the Cup-strebe.
I've welded two more pieces of steel in (in comparision with mount from other "factory's") for extra strength at the points were the tubes of the Cup-strebe will contact.
Looks nice huh?
Greetings
Wiebrand
racelook
Post by racelook » Mon Jun 06, 2005 2:14 am
So yesterday finally had some time to work on my car.
At first I maked some changes at the gearboxbracket.
Another shot.
http://www.keversite.nl/fotoalbum/fotos ... 220652.jpg
I attached the stronger noserubber to the gearbox and mounted it to the chassis.
http://www.keversite.nl/fotoalbum/fotos ... 220947.jpg
First tube of the Cup-strebe is ready (still 4 to go).
A view from above
http://www.keversite.nl/fotoalbum/fotos ... 221443.jpg
Front
http://www.keversite.nl/fotoalbum/fotos ... 221540.jpg
That's it for now.
Greetings Wiebrand
supavert
Post by supavert » Mon Jun 06, 2005 4:47 pm
Racelook,
I see that you have a bigger brake line coming from the master cylinder to the front brake lines. Can you tell me why you used that size? because I am also changing all of the brake lines on 74 cabrio and I could use some help.
Thanks, Supavert, Peace!
racelook
Post by racelook » Mon Jun 06, 2005 5:20 pm
Hey Supavert.
I've used instead of the original lines, 6*1 mm Inox lines (originaly used for hydraulic equipments)
Lot's of succes.
Wiebrand
