Project "Racelook"
Yesterday I finish welded the arms of by an friend (wo has a more powerful welder). And it looks them nice. The future will tell it they are too heavy.. if so I let them machined to get the sideplates a little thinner.
Also yesterday wanted to weld some plates in the "napoleonhoed because it had some little rotten place. But when I had it cut out.. it was totally rotten. SO there have to be welded an new napoleonhoed and an new underplate for that thing on my "I thought paint ready" chassis. But hell yeah.. it just keeps me going
Nothing more was done because of helping my brother with his engine-change for his Opel Astra (Vauxhall) from 1.6 to 2.0 16V. Yesterday we welded an half of the exhaustsystem so it could fit.
Here ar some pictures.
Thursday I had drilled some small holes in the midmount. It's now finished.
And the finished control arms.
http://www.keversite.nl/fotoalbum/fotos/21732.jpg
Enjoy Wiebrand
Enjoy Wiebrand
- Ephry73
HEHEHE.. Finally an little update!!
Had found some sparetime on second christmasday (before the family-stuff begun).
At 10am got the drill and angle grinder together to start working, with the following result:
First begun to make al the welds of the napoleonhead and the chassishead "clear". Than noteded soem measurements.
After that drilled some spotwelds and cut the napoleonhead of.
Then cut away the other pieces and that givese this result.
After some grinding it looked like this.
The underplate of the chassishead is temperwarely on this place, as "mold" for the napoleonhead. After the napoleonhead is welded the hole underplate will be changed.
The "tubes" on the outsides of the head are extra welded, the inside is maked clear and painted with sincspray.
And an testfit. (it's not totally ready but this is how it would look like)
http://www.keversite.nl/fotoalbum/fotos/22043.jpg
Also the underplate of the chassishead is maked clear, the nuts are extra welded and all is sprayed with sinc.
This all done in 5 hours and 24 minutes Smile
And quick the differents of the excisting napoelonheads.
Top: The cut away one
Middle: Napoleonhead for the "older" type of bugs
Bottom: Napoleonhead for 1303
Greetings Wiebrand
p.s. sorry for the bad english
Greetings Wiebrand
No, the napoleonhead for the 1200/1300 is thinner, and the ends of the head are different than the napoleonhead for the 1303.Passatman wrote:Racelook is the napolenhead for the older type bugs 1200, 1300 the same size as the 1303.
Also the holes for the MC are on an different place (1200/1300 = ready to fit an Porsche MC).
Wiebrand
SOOOOOOOOOO everybody ready for another update??!!!
Friday morning had some time to remove some pieces of the old napoleonhat so the new one could fit nicelly. Some bending, some hitting with the hammer and it fits.
This afternoon at an hour or 2 (p.m) starting working again on the bug (it was an hard day yesterday evening... Beer... LOL ). At first drilled holes in the edge of the napoleonhat so I could weld it on the chassis. After some measuring welded in the hat.
After that started on the underplate of the chassishead. The spotwelds hitted with the centerpons and drilled through.
http://www.keversite.nl/fotoalbum/fotos/22366.jpg
At an hour or half past five it was like this.
With this as the rusty cut-out pieces.
Also tonight from 20.45 till 22.45 worked on the car and this is how it looks till now.
pfff what is my car an rotten piece of poop.. I just can't believe it every time... from the outside you see nothing but from the inside it's became 3mm thicker .
Wiebrand
Wiebrand
