412 window rubber.....
Discuss with fans and owners of the most luxurious aircooled sedan/wagon that VW ever made, the VW 411/412. Official forum of Tom's Type 4 Corner.
vdubinluvin
Post by vdubinluvin » Mon Mar 05, 2012 12:28 am
I'm going to start the redue on my 74 412 and need to figure out what to do with the window rubber. I know you can use bus rubber for the front and rear glass but what about the quater rubber? I want to retain the molding also any hints? Ray?
vdubinluvin
Re: 412 window rubber.....
Post by vdubinluvin » Fri Mar 09, 2012 12:52 am
35 views and nothing........:-)
bradey bunch
Post by bradey bunch » Fri Mar 09, 2012 9:21 am
I talked to my glass guy and he said he could get me something, have you tried a glass shop?
vdubinluvin
Post by vdubinluvin » Sat Mar 10, 2012 1:34 am
I have talked with a few but no dice
type4ever
Post by type4ever » Tue Mar 20, 2012 10:05 am
Send an e-mail to info@keverspecialist.nl in Holland.
I think they can help you.
Ton
wshawn
Post by wshawn » Wed Mar 21, 2012 4:14 pm
type4ever wrote:Send an e-mail to info@keverspecialist.nl in Holland.
Ton
Got mine from there and a great fit
vdubinluvin
Post by vdubinluvin » Sat Mar 24, 2012 11:54 pm
Ton
Thanks for the tip just messaged them :D
Your eaten is the same color as mine L98 I believe
raygreenwood
Post by raygreenwood » Sun Apr 08, 2012 4:55 pm
Sorry for the delay in answering. By next month i will have my car back in my hands and out of storage. there is a very simple method i cooked up to reliably use type 1 or early bus rubber to replace type 4 rubber. It requires making an adaptor/gripper/spacer insert that goes against the vertical side of the ledge or channel. If you look at all the seals in cross section, thpough the dimesnions vary they are enough the same shape that they can work if cany major gaps are filled. The most glaring major gap between type 1 and type 4 rubber is where the little flexible ribs are that squash against the vertical sideo fthe channel. the type 1 rubber is not as deep here.
What I will use is ribbed industrial V-belt rubber that has been poprivted and sealed against the vertical wall of the channel. I have several rubber suppliers that will sell varying widths by the foot. Nore to come. Ray
dubsonjim
Post by dubsonjim » Fri Oct 04, 2013 12:55 pm
any update on this?
raygreenwood
Post by raygreenwood » Fri Oct 11, 2013 5:31 pm
Not yet. Still under the front end. Ray
