Update and improvements on my Oxy build
grelland
Re: Update and improvements on my Oxy build
Post by grelland » Wed Jan 10, 2018 3:16 am
jackstraw wrote:
Tue Jan 09, 2018 8:48 pm
Great job. Liking the pics. I'm curious about the strength of a 3D printed whatever. Interesting technology.
These prototypes are printed in PLA and will most likely not hold up well, but I have more engineering-friendly material like nylons that should be more durable if I decide to actually use 3D-printed parts. I have 3d-printed a radio block-off plate which we sanded and painted, so I already have some 3d-printed parts in this car:
grelland
Post by grelland » Thu Jan 11, 2018 4:55 am
It was my yongest son's birthday yesterday (turning 12), and when I aske what he wanted to do, he wanted to spend some time with me in the garage ;)
SO we had a look at the pulleys, as I had some issues last summer where I used a wbx crank pulley, butr that had a very different offset than a type1, so I had to shim out the upper pulley way too much.
I trial fitted a type1 pulley that had the "threads" machined down, and then the alignment is much better. Still need some fine adjustments with shims, but this will be good.
I also (thankfully) noticed that I had forgotten one of the blind plugs on the flywheel side of the case, so the flywheel had to come off again.
ajdenette
Contact:
Post by ajdenette » Fri Jan 12, 2018 5:41 pm
lucky catch on the missing plug that could have caused a big head ache.
Alex
|_________oo_oo
/ /__/____[_____\
I I======[]IIIIIII[]
()_)-----()_)----)_)
andy198712
Post by andy198712 » Wed Jan 17, 2018 6:14 pm
I’ve made that mistake! Great thread thanks for sharing :)
