Cam Bearings for 2270 Build
Moderator: Piledriver
Bsherrard
Post by Bsherrard » Sun Jan 07, 2018 8:43 am
I am trying to source a set of double thrust cam bearings for my 2270 build. I was able to find NOS Mains and Rod bearings at the local VW parts shop here in Orlando and what I thought was NOS Cam bearings but they turned out to be for a type 1 (Glycols). The only place I seem to be able to find a set is at the Type4 Store but they are awfully pricey ($115) considering I paid $75 for mains / rods and cam from the local guys. Anyone have any ideas or is this just the current state of affairs with our engines? Also - it seems that the only difference between a single and double thrust set is swapping out the one half shell with one with thrust so you could possibly create your own set with two sets of standard - is that correct?
sideshow
Contact:
Re: Cam Bearings for 2270 Build
Post by sideshow » Mon Jan 08, 2018 8:14 am
On my personal engines I quit buying cam bearings type-4 included. Core bearing are fine, if the thrust isn't wiped out and another thrust and be done with it. The only thing I might consider is beating a locking tang into both sides.
Redline is just a suggestion, much like new parts
raygreenwood
Post by raygreenwood » Wed Jan 10, 2018 11:17 am
You can get them at the type 4 store.....and at least you used to be able to get them at Aircooled.net.
Ray
Post by Piledriver » Wed Jan 10, 2018 11:00 pm
Double thrust cam bearing sets are assembled, not made...
two sets of cam bearings is a lot less than $115.
Two sets of Mahle cam bearings typically run about $30.
Cats been out of the bag awhile...
https://www.thesamba.com/vw/forum/viewt ... t+bearings
That little tang isn't what keeps the bearings from spinning in the case...
It simply makes sure the split is aligned with the split in the case, bearing crush prevents rotation.
File the extra tang off.
sideshow
Contact:
Post by sideshow » Sat Jan 13, 2018 12:58 am
File a notch into the cam bore, hammer it to fit.
