2,23 ltr type 4 turbo build-up
Moderator: seabeebuggy
Kalle
Re: 2,23 ltr type 4 turbo build-up
Post by Kalle » Sun May 27, 2018 10:49 pm
Happy birthday Wally and congrats with the impressive results on the dyno. There is potential there for whole lot more when you get everything under control and increase the boost.
Take care my friend and enjoy the day and remember: pedal to the metal!
-K-
Wally
Post by Wally » Mon Jun 18, 2018 4:06 pm
First test runs at our local track and national event at Wanroij, Netherlands. Just a 125meter 'track'.
It was fun nonetheless. Boost set at 0.65 bar :wink:
Good test as some small issues came up, but we drove to and from the event on our own wheels without problems :D
https://youtu.be/mORbikvqoy4
T4T: Type 4 Turbo engine, under construction
buguy
Post by buguy » Mon Jun 18, 2018 6:09 pm
Sounds great!!
Udo Airbus
Post by Udo Airbus » Mon Jun 25, 2018 5:55 am
wauw gaaf Walter! Very cool!
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
Wally
Post by Wally » Mon Aug 20, 2018 7:42 am
Unfortunately, the one-off cast alu cylinders proved to be too soft/weak as the material was compressed somewhat probably and also the bore openend up top and as a result of this finally a desastrous leak occured, which drew in fresh air on suction and made a torch of the mixture in that cylinder:
Damage is one cylinder, one head and one Raceware stud. Pistons are (fortunately) in great shape however.
All bores had a pretty big taper, so material was obviously not strong enough despite 9mm (!) wall thickess.
The taper also explained the somewhat excessive blow-by I encountered under boost..
New cylinders will be 98mm birals from AA with new regular JE piston rings.
I could order 1 new stud from Raceware (tnx guys!) and Jacob fixed the head: awesome!
The 98mm AA's are just 3,5mm wall thickness, so I am a little concerned there, but 94mm type 1's aren't much thicker afaik, so fingers crossed...
Learned something the hard way, but other (to me new) things in the engine did work out very well, so lets move on!
andy198712
Post by andy198712 » Mon Aug 20, 2018 8:02 am
Nasty way to learn :(
When your pushing the design of these engines to new highs I guess you’ll find some limits of certain parts.
Keep up the good work :)
rubenski
Post by rubenski » Mon Aug 20, 2018 8:33 am
I cracked 3 pistons, I know the feeling!
Its a PITA but learn the lesson and move on!
Greetz!
petew
Contact:
Post by petew » Tue Aug 21, 2018 10:56 pm
Ouch!
mactaylor
Post by mactaylor » Wed Aug 22, 2018 12:14 am
Tune was fat Wally?
Wally
Post by Wally » Wed Aug 22, 2018 6:56 am
It was turbo-rich so to speak 😉
AFR was not the issue here..
mactaylor
Post by mactaylor » Wed Aug 22, 2018 11:03 am
Thought the lining in the cylinders may have been good enough! obviously not!
Wally
Post by Wally » Wed Aug 22, 2018 2:48 pm
No, lining held up, that wasn’t the problem either. If the tension between head and cylinder gets less and less, this is what will happen. And it wasnt the studs either. Cause is in my original post before just to be clear on what happened ;-)
ssrt
Post by ssrt » Fri Sep 07, 2018 12:09 pm
How much did you touque those raceware studs?
Wally
Post by Wally » Sun Sep 09, 2018 2:35 pm
The original value (23 lbs.ft iirc)
petew
Contact:
Post by petew » Tue Sep 11, 2018 8:57 pm
So what's your plan for the rebuild? Iron cylinders? What about Deuz cylinders?
