Engle FK8 cam...opinions
Moderator: Tom Notch
vujade
Post by vujade » Wed Apr 14, 2004 12:46 pm
I just bought the makings of a 2276 or a guy that bailed on his project and it came with an engle FK8 cam.
Anyone running one of these on the street?
What is the power range?
This motor is going in a street car that will see track action at least once a month.
Should I keep this cam or sell it and buy a Engle FK89 which I originally intended to use?
Lymkey930
Street Cam
Post by Lymkey930 » Wed Apr 14, 2004 1:50 pm
You would be doing yourself a favor to stay with the FK8 rather than going with the FK89(race only) cam. The FK8 would be a very streetable cam with 1.4 or 1.5 ratio rockers and still allow some track time opportunities if the rest of the engine/transmission combination is set-up properly.
DesiJae
Post by DesiJae » Wed Apr 14, 2004 2:31 pm
I use the FK-8 VERY DAILY! on a 2275 (9:1). You will ask your self why you never used it before. Very fun cam.
masoliven
Post by masoliven » Wed Apr 14, 2004 3:56 pm
I have heard nothing but good things about the FK-8. Im buying parts right now for a 2332. And originally I was going to go with the FK-8. But now as I have decided to really get serious about drag racing I am going with FK-89. I will be putting the Fk-8 in the next motor for my street car. Probly a 1915.
DRD
Re: Engle FK8 cam...opinions
Post by DRD » Wed Apr 14, 2004 4:27 pm
vujade wrote:I just bought the makings of a 2276 or a guy that bailed on his project and it came with an engle FK8 cam.
The K8 is a good street car, pump gas cam, good power from idle till around 6500 to 7000 rpms. You will be very happy with it.
The fk 89, is intended for drag racing, high compression engines. Yeah you might hear people rant and rave, I have a 89 in my street car and drive it, and I am sure they do. The power band comes on at 5k and stops at were the valves float, on top of lossing cylinder pressure on the lower rpms, and giving up the life of cam.
Good Luck.
vujade
Post by vujade » Wed Apr 14, 2004 6:08 pm
thanks guys...
what about the new FK40 cam, its supposed to be in between both of these cams..?
DRD
Post by DRD » Wed Apr 14, 2004 6:15 pm
vujade wrote:thanks guys...
What heads are running? Set your engine up around the heads and fuel you are going to use..More duration on the cam , will let you run more compression.
Lo cash lester
Post by Lo cash lester » Wed Apr 14, 2004 9:19 pm
The FK-8 is a good versital cam. :lol: I ran it with NOS on an 1835cc and got a best of 7.24@96mph in the 1/8th. The same motor now has a turbo on it and is in the SSG. Not an all out race cam but for a daily driver it will work great. I'm using an FK-45 on a 112 lobe for the turbo/NOS motor in MT, haven't fired it yet but I will be soon. I liked the 45 for the lower duration and more lift then the FK-10 I was going to originally use.
sixTsix mike
Post by sixTsix mike » Wed Apr 14, 2004 10:32 pm
any of you florida boys have a "beefed" up tranny you wanna get rid of?
Thai_1_On
Post by Thai_1_On » Wed Apr 14, 2004 10:51 pm
I want to know where all you Fla. guys are finding all these abandon engine projects? :x
Sorry for the thread hijack but i couldn't resist and besides sixtsix started it :wink:
James2
Post by James2 » Thu Apr 15, 2004 7:56 am
I'd stick with the K-8, the low end torque makes the car easier to drive on or off the track.
The FK-89 could actually make LESS power if you don't bump the CR by a good bit.
1969dragbug
Post by 1969dragbug » Thu Apr 15, 2004 7:59 am
sixTsix mike wrote:any of you florida boys have a "beefed" up tranny you wanna get rid of?
I have a done up IRS one I would sell. Send me an email.
vujade
Post by vujade » Thu Apr 15, 2004 8:13 am
the heads are CB Ultramags ported by Jeff Denhem
autocraft 1.4 ratio rockers
eagle 5.5 H beam rods
Mahle 94s
Scat 82 Forged crank
going to run 10:1 Compression
Btw, I am also looking for a swing axle tranny, preferably with 3.88 r & p
Who is online
Users browsing this forum: No registered users and 2 guests
