twin plug ignition
greg
twin plug ignition
Post by greg »
Hi Jake, I was reading a few of your posts on the heads you run with twin plugs. You said that you have no problem lighting them because you use a DIS or direct fire system or something. Do both plugs in the same cylinder fire at the same time or is there a primary and secondary spark?Well I want to run a twin plug system on a 2332T type 1 I am building but cannot afford anything moe than $600. What could I do to still light 8 plugs? I have access to a Nissan Z22 dizzy you spoke of, and was thinking of either wiring 2 comp u fire DIS boxes together, and if all else fails go with the unit greatplains offers running of the oil pump. I just want something as simple as possible, at a resonable price. Thanks
Post by MASSIVE TYPE IV »
My engines that run twin plugs also run EFI that incorporates direct ignition.
I have done it with carbs before by using the electromotive HPV-3 modified for twin plugs, but now the cost of that unit is almost 900 bucks.
The other way i havedone it was with a modified dizzy from a Datsun Z22 engine. The Z22 was a twin plug 4 cylinder with a funky cap and odd dizzy. Its not really difficult to modify to work well in a VW engine.
volkaholic1
Post by volkaholic1 »
I ran a dual distributor for quite a few years on my turbo ghia. Check out the pics on my web site, bottom of the page:
http://www.awesomepowdercoat.com/miscprojects.html
I finally gave up on it because I could not control the advance curve. too much variability due to the toothed belt drive.
Also, doesn't Compufire make a "distributor-less" ignition that uses the stock dis with a special cap, then 4 coils? Could you buy 2 of these, then use 1 cap to drive all 8 coils?
I tried this in 2001 the result was fried components. I called compfire and they said the circuitry would not support the added load. i didn't believe them till I baked the unit.
greg
Post by greg »
Jake, I have one of those Z22 distributors and wouldn't mind going that route. If you could please tell me all that I have to do modify the thing. I could send you all the pics you need if you could just walk me through the thing or even better I am willing to send you one and pay for the modification.
Volkaholic, I wouldn't mind gonig that route either, but realistically what are my chances of finding one of those dual dizyy set ups. Any more info would be great. Could you install 2 Pertronix/Comp u fire units into those 009? I was wondering same thing about the dual Comp U Fire DIS systems, because then I also have my performance ignition all wraped up.
Thanks guys... -Greg
volkaholic1
You are right, the odds are low that you would find a dis exactly like this one, they stopped making it for the reasons I wrote about, I just was giving you ideas. So, I would not recommend using what I tired.
I could fit 1 Pertronix unit in the main dis, but the secondary only had room for points, it was real tight.
Can Drive Soon
Post by Can Drive Soon »
http://www.precisionmatters.biz/product ... index.html
Looks like a neat kit, sorta like the one posted but runs off of a gear drive, not a belt.
R2.0
Post by R2.0 »
I think there are some folks over on the Megasquirt forums running dual plug MS&EDIS.
R2.0
1972 Karmann Ghia Convertible
"As God is my witness I though turkeys could fly." - A. Carlson -
greg
Post by greg »
Bump for a reply on the Z22 distributor question/request Jake. Thanks -Greg
Which Z 22 dizzy is it? There were 3... what year was the truck?
greg
Post by greg »
It acctually came off of a 1986 Z24 truck. I didn't think there were 3 types. If the one I have cannot work I know the junk yard I go to has a couple of Z22 distributors in 200SXs. Here are two pics of the one I have, I can take more if you need. I really want to do this mod Jake so thanks for help. Please let me know if you need more pics or what ever. I just need you to walk me through this. Thanks a million.
http://pg.photos.yahoo.com/ph/gcmesa/al ... /my_photos
[/img]
Dstar reports Bosch sells a Mercedes cap/rotor for dual plugs/coils that IIRC fits stock ACVW distributors... Dual coil 8 cyl cap.
Haven't seen it/tried it.
I also have floating around somewhere an old Goldwing breaker plate, If I can find it again, I was planning on adapting it to an old stock VW dist for a DIS waste spark setup....
Sadly DYNA doesn't make the DYNA3 anymore, it could probably drive 4 DIS modules directly to 15K if needed...
It could easily trigger a pair of Vanagon modules driving pairs of DIS coils, or easily drive a set of modern COP modules, as the signal would truly be a trigger.
Should be no smoke involved, DIS coils work well @3.5A, just use `em in pairs with a ballast.
If one can score HD or Mitsu COP modules, thet have integrated ion-sense knock detect logic outputs that are directy usable, assuming ones ECU has a knock detect input(s)
greg
Post by greg »
Sorry dude, you completely lost me after the Mercedes cap/rotor...
I'll try and PM Dstar for the info or maybe he can drop in. Thanks
greg wrote:Sorry dude, you completely lost me after the Mercedes cap/rotor...
Sorry :oops:
Ignition stuff is just trivial electronics.
There are many ways to light things up.
dstar5000
Post by dstar5000 »
Yes, I found a Mercedes cap that fits the Bosch and was an 8/dual
plugger. Since I'm not into EFI yet, I've pretty much forgotten what
and where it was. I just remmeber that it *lives* and is obtainable.
:D
Porsche also ran a twin plugger in 54-55, but I don't know how they
fired it. IF it was from a standard type dizzy, then all you have to do
is find a 54-55 Porsche 1500RS dizzy and cap! :lol:
Let me get a cup of coffee or two and I'll get back to ya!
:lol:
Don
Locked
