Stroker case clearancing
Is ther any pix or links for this?? or do i assemble and mark where everything hits and grind till the cows come home,LOL
- BigOlJohnson
- Muffler Mike
not to say it can not be done at home, I know it can, but just think of the mess it will make. I have done some touch up clearancing in cases and what little i need to do, makes an ugly mess with particles flying every where, even with a vacuum running close by.
but if you must see, i have a few pics of where most of the general clearancing is done for larger strokes.
- Muffler Mike
http://www.harborfreight.com/cpi/ctaf/d ... mber=44141
one could use an electric rotory grinder like in the link above.
I use to use one like that.
the down side, they are not quite as nimble and typically are not variable speed. (last i checked mikita made a variable speed)
But that might be an option for one that does not have a good compressor.
As far as compressors are conserned, if you want to invest in one, get a good ole fashion piston pump compressor.
this is what i ended up with and so far, it will run a good quality die grinder as long as i need. I run an air saw and air hammer with it too.
http://www.sears.com/sr/javasr/product. ... Cookie=Yes
So now that we have spent 1000 in tools to do a 100 dollar job.................................LOL. guess it depends on weather you plan to use these tools more often.
And by the way, Rimco and a few others get around 70-75 bucks for a generic case clearancing for up to about an 84 stroke
Hey guys ,Since I have these neet porting tools laying around from C.C Specialty,I thought I would Try and wear them out,since i didn't on my kids Cast iron heads for his MudBogger,LOL and yes there Electric w/foot control, one of the best shop tools i ever bought.thanks,can't figure out how to attach pic?,Mike
Mostly to 64Bug
I bought a super case and still had to do a lot of clearance work. Nothing major, but everything had to be doctored a bit.
