More Engine Building and Tips Links see pages 2 & 3
Moderator: sparkmaster1
perrib
Post by perrib » Sun Dec 28, 2008 1:13 pm
I did not find a torque spec page in the sticky. Post what you can find. Once completed it would be nice to make it part of it.
TORQUE SPECS in FOOT POUNDS
RIMCO SUPER ROD
28
CB RODS
Connecting Rod Bolts
Stock T-1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 ft/lbs.
UniTech. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 ft/lbs.
Uni Tech HD w/ARP 3/8" bolts . . . . . . . . . . . . 45 ft/lbs.
CB H-Beam/ARP Bolts . . . . . . . . . . . . . . . . . . . . 29 ft/lbs.
SCAT 7/16" diameter bolts for VOLKSTROKER II PRO-DRAG CRANK 82-85
SCAT 4340 Chromoly Gland Nut 250
SCAT 10mm Chromoly Cylinder HeadStuds/Nuts 23-25
SCAT 8mm Chromoly Cylinder Head Studs/Nuts 18-20
SCAT KILLER™Case Main Studs (6 each) 40
SCAT KILLER™Case all other 5/16" bolts 15
SCAT SPLIT-PORT Cylinder Head 5/16" bolts 15
SCAT Bolt-on Valve Cover Bolts 5-18
VW Engine Case Main Studs (6 each) 25
VW Engine Case small nuts 15
Rocker Shaft Hold Down Nuts 15-18
Cam Gear Bolts 18-20
Drain Plate Nuts 5
Drain Plug 25
Pressure Plate Bolts 18
Oil Pump Nuts (8mm) 5
Crank Pulley Bolt 29-36
Generator Pulley Nut 40-45
Fan Nut (Large) 40-45
