Exploded Views of Rear Axle Components
Swing Axle Type 1
IRS Type 1
IRS Transmission Rear Suspension Exploded Diagram Posted: Mon Jan 07, 2008 8:32 pm Views: 947 Rating: Not rated
Please Rate It: Rating 1 - Low2345678910 - High
#1 Torsion Bar
#2 Inner Spring Plate Grommet
#3 Spring Plate
#4 Outer Spring Plate Grommet
#5 Spring Plate Caps
#6 Trailing Arm Pivot Bolt (M14x1.5mm threads)
#7 Trailing Arm Bolt Washer
#8 Trailing Arm Pivot Bushings
#9 Trailing Arm
#10 Control Arm Rubber Stop
#11 Inner Axle spacer
#11a Sway-A-Way Axle Spacer
#12 Seal Stub Axle Inner
#13 Control Arm inner snap ring
#14 Inner Control Arm Axle Bearing
#15 Axle Spacer between Bearings
#16 Plastic Emergency Brake cable holder
#17 Outer Control Arm Axle Roller Bearing
#18 Large "O" ring
#19 Small "O" ring
#20 Bearing Cap
#21 Outer Axle Spacer (Seal surface)
#21a Sway-A-Way Axle Spacer Kit
#22 Seal Outer Stub Axle
#23 Bearing Cap Bolts (M10x30)
#23a Spring Washer
#23b Flat Washer
#24 Rear IRS Brake Drum
#24a Lug Bolts
#25 Rear Axle Nut Flanged
#26 Cotter Key Large
#27 Upper Shock Bolt
#27a Nylock 12-1.5mm self locking nut
#28 Rear IRS Shock
#29 Lower Shock Bolt
#29a Nylock 12-1.5mm self locking nut
#30 Rear Axle
#31 CV Bolt
#31 CV Bolt Washer
#32 CV Bolt Plate
#33 CV Axle Boot with Flange
#34 Washer
#35 Constant Velocity Joint
#36 CV Axle circlip
#37 Stub Axle
#38 Grease Cup used in some CVs
#39 Large CV Boot Clamp
#40 CV Boot
#41 Small CV Boot Clamp
panel wrote:I found a pic.
Thanks Lew for posting this.
Re: Exploded Views of Rear Axle Components
Chris V
Post by Chris V »
As far as the IRS wheel bearings go, when trying to remember their placement, it always helped me to say, "balls with balls"...aka, ball bearing goes closest to CV joint (w/balls).
OK what is the deal with the spacing when you add rear disc brakes into the mix. Is the thickness of the caliper bracket the same as the thickness of the drum backing plate? I don't have pics of the rotors but one of them is trashed the splines are really stretched, the other one is questionable. Does anyone have the specs on the splines?
Stray Catalyst
Post by Stray Catalyst »
This looks helpful. Any way you could post the same for Type 2 SA? I'm struggling with the trans swap for my 64 bus.
Stray Catalyst wrote:This looks helpful. Any way you could post the same for Type 2 SA? I'm struggling with the trans swap for my 64 bus.
It has redux boxes doesn't it? And should be a small nut..............
Stray Catalyst
RGBs and large nut - the trans may not be original.
Thrown Hammer as a good thread I think it was called the ultimate gear reduction thread or something like that.
Post by Marc »
Stray Catalyst wrote:RGBs and large nut - the trans may not be original.
`63½-`67 were large nut.
