2,23 ltr type 4 turbo build-up
Moderator: seabeebuggy
Wally
Re: 2,23 ltr type 4 turbo build-up
Post by Wally » Sun Feb 19, 2017 7:33 am
Fitted most things, now need to trial fit inside, so one last pic outside the car:
petew
Post by petew » Sun Feb 19, 2017 5:24 pm
That is 18 kinds of awesome. :)
Wally
Post by Wally » Sun Feb 26, 2017 11:50 am
Cheers Pete!
I also managed to fit the type 1 exhaust after some fittling..
Clonebug
Post by Clonebug » Sun Feb 26, 2017 12:28 pm
Beautiful Wally!!!!!
Wally
Post by Wally » Wed Mar 01, 2017 10:51 am
Cheers!
Even more happy was I with today's package that arrived:
petew
Post by petew » Wed Mar 01, 2017 3:46 pm
:shock: :shock: :D :D
Kalle
Post by Kalle » Thu Mar 02, 2017 6:30 am
That big box for such a small turbo.... :-) :-)
66brm
Post by 66brm » Thu Mar 02, 2017 6:45 am
It comes flat packed from Ikea
Kalle
Post by Kalle » Thu Mar 02, 2017 7:02 am
:D :D :D Well spotted! I see it now.
Wally
Post by Wally » Thu Mar 02, 2017 4:53 pm
:lol: :lol:
Fysical size doesn't probably tell the whole story here :wink: :wink:
panel
Post by panel » Thu Mar 02, 2017 11:38 pm
What is the electronic actuator for ?
Subaru JDM EJ20 Turbo bus
Wally
Post by Wally » Fri Mar 03, 2017 5:17 am
Its an 'intergrated' Boost Control Valve. You can also see the intergrated BOV and on the bottom (not really visable) is a pickup point for a shaft speed sensor . All these items are a standard part of these turbo's: EFR: Engineered For Racing :mrgreen:
The turbine wheel is made from Ti-alumid alloy and half the weight of an inconel wheel as seen on other turbo's like a GTX, whatever Gen they are 8)
Plus of course the forged billet alu compressor wheel with 65 lbs flow capacity and the duel row ceramic ball bearing cardridge and the stainless steel twin scroll housing with V-band.
You can tel I like these. A lot :mrgreen:
Post by Piledriver » Fri Mar 03, 2017 5:28 am
I have wondered if the greased (sealed) ceramic bearing turbos might work on an ACVW---
no oil flow, need the lower EGT of a long tube setup, but can be mounted any orientation.
Just musing, slick setup, as expected.
Wally
Post by Wally » Fri Mar 03, 2017 6:45 am
no oil flow, ..
These turbo's do use an oil feed (and return obviously) however, same as any other turbo.
RJVolksperformance
Post by RJVolksperformance » Fri Mar 03, 2017 1:30 pm
Walter,
I like that type 1 is becoming more common used words in this thread, I knew you would see sense in the end :D
Looks good mate 8)
cheers Richie
