In distributor crank triger 24/2 wheel
Moderator: Tom Notch
woodsbuggy1
Re: In distributor crank triger 24/2 wheel
Post by woodsbuggy1 » Sat Sep 26, 2015 10:25 pm
Is anyone out there marketing the 24/2 dizzy crank trigger these days? I have emailed the gentleman on the Samba(with no reply) and have noticed that his ad is no longer listed. I was planning to modify a CAS from a Nissan SR20DET engine but this seems like a much simpler solution.
Kenric
Post by Chip Birks » Sun Sep 27, 2015 1:22 pm
Do you currently have a standard 36-1 wheel? Why not just toss a modded vanagon distributor in there. Cheap and easy mod if you want to go sequential. I got one for free from a guy that was doing a subie swap.
woodsbuggy1
Post by woodsbuggy1 » Tue Sep 29, 2015 10:18 am
I m looking for a more offroad friendly trigger wheel. I like the idea of having everything protected under a cap. Then I don't have to worry about mud, water etc. I am not interested in fully sequential just a sealed unit.
Thanks Kenric
vwi_dduvall
Post by vwi_dduvall » Tue Sep 29, 2015 10:52 am
woodsbuggy1 wrote:Is anyone out there marketing the 24/2 dizzy crank trigger these days? I have emailed the gentleman on the Samba(with no reply) and have noticed that his ad is no longer listed. I was planning to modify a CAS from a Nissan SR20DET engine but this seems like a much simpler solution.
Kenric
I found that he does reply to his Ebay account (racemachineinc) he might take a bit as he is real busy.
Daniel Du Vall
http://volkswageninsanity.us
"Cause, remember: no matter where you go... there you are"
Buckaroo Banzai Across the 8th Dimension
Post by Piledriver » Tue Sep 29, 2015 12:31 pm
woodsbuggy1 wrote:I m looking for a more offroad friendly trigger wheel. I like the idea of having everything protected under a cap. Then I don't have to worry about mud, water etc. I am not interested in fully sequential just a sealed unit.
Thanks Kenric
If you order the 24-1 wheel from him it will also support fully sequential, he can make them either way.
The 24-2 (with opposing missing teeth, faux 12-1 missing tooth crank wheel) is meant for ms1, waste spark only.
The 24-1 VR setup Redline Weber sells is also an option.
Post by Piledriver » Fri Mar 25, 2016 8:39 pm
Bumping this, sorta, had some requests for pics of my DIY setup, this currently resides on my desk awaiting being finished.
I've had a very similar 36-2 setup in the car for ~20K miles now.
This is a 72-1, filled in tooth, sensor will not work right with one filed out.
(That's how I found 36-2 still works)
Looks like the older posted pics were (temporarily?) lost in the board upgrade.
If you polished the ends of the teeth and/or maybe tipped them with retroflective paint you could use a reflective optical sensor instead.
You could then fill the gap with epoxy or file a tooth out... You could even use a fiber optic unit and keep the electronics out of the engine compartment entirely.
Lingwendil
Post by Lingwendil » Fri Mar 25, 2016 9:16 pm
Cool! Is that link I sent you the same gear? If so I'll post it up so we can share the love.
Looks like a good use for all the DVDA, SVA, and knock-off 009 dizzies floating around. I've got an old 205T with a bad vacuum can this would be perfect in.
Silly idea- Could leave all the guts in for a mechanically controlled advance curve, leave the distributor body set at 0° and let the limp-home-mode of an EDIS get your idle timing at 10° BTDC... This would let you slave the EDIS off of the curve of the distributor, but you would still have working advance. This may be of some merit if you have a snazzy dizzy that has been worked over enough to give the curve you or your engine like.
Goofy, but in theory it should work, and you get higher spark energy, and still get less timing scatter than a dizzy could do on its own. Assuming of course you can get the sensor to work with the EDIS module, which should be just fine I'm thinking... Good for folks that are scared of running a dedicated controller...
I'm still looking at the best way to get into crankfire on the cheap, but this looks like a tempting kludge until I get a megajolt or megasquirt.
Post by Piledriver » Fri Mar 25, 2016 9:33 pm
IF you cut opposing teeth off on the 72 tooth wheel ... AND could find a VR sensor that worked with the fine pitch wheel AND EDIS, it might work.
You go first.
Would be easier to use a simple 4 tooth trigger and drive a Bosch coil driver in that case, the hall sensor would work doing it that way. keeping the cap/rotor etc.
You could even do waste spark, say using a VW 4 tower coil off a new beetle etc.
(needs 2 wheels/ sensors 90 degrees out to do it all in hardware I think, still processing, easier with electronics methinks)
You aren't gaining that much without the programmable ignition, just a hotter spark and maybe +reliability by ditching the cap/rotor etc.
The programmable part is the much bigger win IMHO.
On a hot engine with a big cam you aren't going to get effective "vacuum advance" without it, and its essential to keep down CHT/EGT, get decent fuel economy, and really run right at anything other than WOT.
BTW, the first setup (like this) I tried was a Mallory Unilite with extra slots milled in the wheel, 16-1.
Also tried turned down the upper shaft on a 009, keeping the rotor drive part intact.
Either could still be used as a distributor if so inclined, with a Megasquirt controlling timing.
Only useful if you want the olde skool look or are in a racing class that requires a distributor IMHO.
woodsbuggy1
Post by woodsbuggy1 » Wed Mar 30, 2016 9:03 pm
I just received a reply today from the person making these, I will be running MS3x with wasted spark and FI, I was planning on a 24/1 wheel unless there are better suggestions.
Kenric
Post by Piledriver » Wed Mar 30, 2016 11:01 pm
woodsbuggy1 wrote:I just received a reply today from the person making these, I will be running MS3x with wasted spark and FI, I was planning on a 24/1 wheel unless there are better suggestions.
Kenric
It will work fine.
woodsbuggy1
Post by woodsbuggy1 » Fri Jul 28, 2017 8:54 pm
I finally got my new motor finished and am trying to make this unit work but cant get my spark figured out. The wheel that I have is 24-1-1 (in megasquirt terms) 22 teeth with 2 missing teeth 180 deg apart. Any suggestions?
Kenric
Post by Piledriver » Fri Jul 28, 2017 9:31 pm
You could tell MS it was a 12-1 at crank speed and run waste spark.
That's the only way to use that particular wheel unless you add an additional cam sync sensor.
If you want sequential on MS2e/MS3 you need a std supported wheel, 24-1 or 24-2 would have worked.
If you got it from the guy over on TOS he knows it matters, but he figures everyone has a MS1 like he does.
Ask him if he has a proper 24-1 wheel you can swap in.
woodsbuggy1
Post by woodsbuggy1 » Sun Jul 30, 2017 12:48 pm
Thanks Pile,
now have it set to 12/1 at crank speed but keep loosing tach signal. it shows 0 rpm about half the time. I had a consistent tach signal before changing the settings to crank based. I am running MS3X V3.57 with wasted spark.
Thanks Kenric
Post by Piledriver » Wed Aug 02, 2017 8:25 pm
Hall or VR sensor is this the setup with the custom distributor cap?
(Pictures might help)
