Building A Water To Air Intercooler
Moderator: seabeebuggy
panel
Re: Building A Water To Air Intercooler
Post by panel » Sat Apr 04, 2015 2:49 am
Also don't forget to insulate it...........viewtopic.php?f=3&t=139988
Subaru JDM EJ20 Turbo bus
risk
Post by risk » Fri Apr 10, 2015 11:24 am
panel wrote:Also don't forget to insulate it...........viewtopic.php?f=3&t=139988
What about some kind of coating? Like a ceramic or heat insulating type?
http://www.yellowbullet.com/forum/showt ... p?t=430122
risk
Post by risk » Mon Apr 13, 2015 6:52 am
Intercooler is done! Now I just need to pressure test it again and make sure there are no leaks.
Ended up cutting the end piece in two, then welding each one to it's respective end tank.
My welds aren't the prettiest but they get the job done.
risk
Post by risk » Tue Apr 14, 2015 2:05 pm
Well.. Almost done. I need to add some bungs for temp sensors so I can measure delta T.
I think I'm just gonna paint it black, then engine turn the front panel to match my firewall.
panel
Post by panel » Sun Apr 19, 2015 12:59 am
Nice intake manifold!
Steve Arndt
Post by Steve Arndt » Sun Apr 19, 2015 9:09 am
Post a pic of your throttle cable and linkage (cable through shroud still?).
Is that a Ford throttle body?
risk
Post by risk » Tue Apr 28, 2015 4:14 pm
Steve Arndt wrote:Post a pic of your throttle cable and linkage (cable through shroud still?).
I will post up a pic once it is all back together. Unfortunately, I didn't have room to run the cable through the shroud like I wanted to. The intake is just too wide right there.
Yes, Ford throttle body off a V8.. around 65mm throttle plate.
risk
Post by risk » Tue Apr 28, 2015 4:16 pm
Still working on getting the engine put back together, but I did get the engine turned finish put on the intercooler.
I plan on painting the end tanks and piping black, then clearing over the engine turned portion.
andy198712
Post by andy198712 » Tue Apr 28, 2015 4:22 pm
Nice!
yvre
Post by yvre » Tue May 05, 2015 2:38 pm
Nice work! Looks like it fits very nice.
risk
Post by risk » Thu May 21, 2015 8:53 am
Intercooler is installed and working well, no leaks! Took it for a drive and did some logging so I could figure out the efficiency. After it was completely warmed up, I took it out on the freeway and flogged it some.
Temp on the intercooler inlet side spiked to 245*F when on boost.
Temp on the outlet side was rock steady at 115*F, would spike to 125*F when on boost.
Ambient air temp was 80*F
So, correct my math if I'm wrong, but:
245-125 / 245-80 = 73% efficient
rubenski
Post by rubenski » Thu May 21, 2015 11:35 am
Wow, nice!
Stripped66
Post by Stripped66 » Thu May 21, 2015 12:32 pm
Great job! Other details of the setup...are you using a heat exchanger? What size water tank?
risk
Post by risk » Thu May 21, 2015 1:14 pm
Stripped66 wrote:Great job! Other details of the setup...are you using a heat exchanger? What size water tank?
Tank is a small 2 gallon aluminum located in the package tray. Heat exchanger is mounted underneath, next to the transaxle.. it's just a radiator off a ninja motorcycle, with an aftermarket 10" elec fan and homemade shroud. I need to take some pictures of everything and post up. I chose that radiator because it fit in the area, plus it had 3/4" inlet/outlet that matched everything else. Pump is a Bosch part # 0 392 022 002
Everything worked out great, although I don't like the idea of a tank full of hot water in the cab.. I may move it up front under the hood eventually.
risk
Post by risk » Thu May 21, 2015 1:15 pm
My next project is gutting my gas heater, and putting a heater core inside so I can use this hot water in the winter for heat :D
Something like one of these..
