Bosch adjustable regulator boost reference bolt
Moderator: Tom Notch
sidemarkers
Post by sidemarkers » Fri Sep 02, 2016 3:59 pm
Just wondering if someone sells the adjusting bolt already drilled out with a hose fitting? I have paypal waiting...
Re: Bosch adjustable regulator boost reference bolt
Post by Piledriver » Sat Sep 03, 2016 4:45 am
I drilled the factory one out, don't go all the way to the end, you want to keep the contact tip intact and use a small hole on the side of the tip to finish the passage or you lose a few pounds of adjustment range.
The hole just has to get past the threads inside the body.
I used a Clippard 10/32 threaded fitting like this on the dumb end, has a 1/4" hose barb, you can get them with push lock quick disconnects in many sizes, brass, plastic or even SS, or just about any other thread/fitting combination imaginable.
Consider the useless rubber gasket to be brain damage and use a smear of anaerobic thread sealer instead.
(The nylon gaskets are ~OK, but use the thread sealer instead in any automotive app)
These work great fabbing a vacuum accumulator, a port on the manifold where you want it etc as well.
http://www.ebay.com/itm/NEW-Clippard-11 ... SwMHdXQxnX
sidemarkers
Post by sidemarkers » Sun Sep 04, 2016 7:05 pm
Awesome response Piledriver!! Thanks so much!
