LED light problem
Moderator: 2088 bob
dustrat
LED light problem
Post by dustrat » Sun Mar 12, 2017 6:30 pm
Decided to change bulbs on my 73 12volt Ghia to LED. Single contact bulbs for flashers and reversing no problem but when I changed double contact stop and tail bulbs only stop lights work. Put old bulbs back in and every thing OK.The contact segments on LED bulbs are the same and as are offset pin fitting I've checked LED bulbs and both stop and tail segments working. Any ideas what might be problem. :?:
Robert
Re: LED light problem
Post by Piledriver » Sun Mar 12, 2017 6:48 pm
I'm running Sylvania Zevos on my 73 T3 (same taillight assy as late Ghia)
no issues: Bright as hell, and work with the reflectors.
https://www.amazon.com/SYLVANIA-ZEVO-Wh ... B01CKQP3XA
Your turn signal flasher may need upgraded to an electronic version, the old school versions relied on lamp current to "switch".
The LEDs draw a lot less current, and may flash very slowly if at all with an original flasher
sideshow
Post by sideshow » Mon Mar 13, 2017 8:04 am
Running lamps are not effected by the flasher. I would suspect a collapsed push pin in the housing if it lights on the bench OK.
Post by Marc » Mon Mar 13, 2017 12:03 pm
Haven't experienced this, but here's a thought. Are you certain that the grounds are good? Specifically, the ground contact between the shell of the lamp and the bulbholder (since the signals work the bulbholder itself must have a good ground). Incandescent double-filament lamps will kinda-sorta work with a bad ground (although with interraction between bright & dim filaments) because current can find an alternate path to ground through the other filament and via the common wiring to the grounds of other bulbholders. Since LEDs only pass current in one direction, that "backfeeding" isn't possible.
dustrat
Post by dustrat » Mon Mar 13, 2017 3:21 pm
Thanks again for advice. First of all I have not changed the flasher unit over but will get a EP35 LED Flasher unit tomorrow. After reading more on the subject it seems that is the problem with flashers. :D Im also going to try something else with tail lights. :idea: The brass tabs on lamp that make contact with bulbs are OK and are making contact with LED bulbs. Current must be coming through as normal bulbs work. Will put another post tomorrow and let you know outcome.
Robert
Post by Piledriver » Tue Mar 14, 2017 3:40 am
One of the bulbs I bought was bad first time out one of the chips was installed backwards, no current=no light.
Buying locally helps, esp if you swap them in the FLAPS parking lot. :lol:
Don't forget the dielectric grease and, clean those sockets, the pot metal sockets are far more of an issue than the brass bits.
Post by Marc » Tue Mar 14, 2017 1:57 pm
di•e•lec•tric (dīˌĭ-lĕkˈtrĭk)►
n.
A nonconductor of electricity, especially a substance with electrical conductivity of less than a millionth (10-6) of a siemens.
Dielectric grease is an INSULATOR, designed to stop the flow of electricity. Legitimate uses are to seal the rubber ends on sparkplug wires or to slather over an already-made-up connection to block moisture from getting to it and causing corrosion.
It should NEVER be used on surfaces that are supposed to be making electrical contact - for some reason in the automotive field its primary use seems to be misuse. ;)
Post by Piledriver » Sun Mar 19, 2017 5:05 pm
OK, you made me look it up...
I had previously posted a long response to that, but it seems to have been digested by the board upgrade.
I'll limit it to this, it only covers "noncritical" appications like aircraft, spacecraft, and nuclear weapons.
The tragedy of Apollo 1 may not have happened if the connectors were properly filled with dielectric grease...
That was a lesson learned the absolute hardest way. (that and don't run electrical junk in pure oxygen)
The proprietary blend used below AFAICT is possibly fluorocarbon grease, although PAO oil is in there too, perhaps as an antioxidant. It may also be just a PAO oil in a teflon-powder based thickener.
(There is such a thing as fluorocarbon soap, so ...)
I assure you its absolutely a dielectric compound, none better..
https://www.google.com/search?q=mil-l-8 ... 8&oe=utf-8
and
http://www.asetsdefense.org/documents/p ... 20Navy.pdf
For most of our more pedestrian uses, silicone grease works absolutely fine, as long as it is a well designed connection with a wiping and spring action. Spade connectors count as long as they are tight.
Ideal use is in a sealed connector, as it wont dry out.
Don't use it on Molex connectors.... In fact, don't use Molex connectors on anything, they suck.
The air and water-tight seal is the goal, Molex connectors have ~no wiping action, and little spring.
Also, don't use it on relays, as at least theoretically silicone oils can outgas and insulate the contacts with silicon dioxide (AKA quartz), and small signal relays usually don't have enough wiping action on the contacts to self clean.
Power relays like you would use in a car usually do, so I don't sweat it.
I don't mount relays where they can get wet as a rule.
Dale M.
Post by Dale M. » Wed Mar 29, 2017 9:17 am
IF you have good solid mechanical contacts in electrical connections dielectric grease is a non issue as insulator, it's beneficial uses are it keep oxygen and moisture out of connection to prevent corrosion... I use it exclusively on almost every automotive wiring project (crimp on connectors) and bulb socket on all my vehicles and in home (yes screw in light bulbs) and have yet to encounter a problem caused by dielectric grease...
As for turnsignal problem, its a flasher issue.... Normal old style flashers are thermal operated and large amount of amperage flowing through them to light incandescent bulb cause flasher to operate... With LEDS the amperage is minimal and will not cause thermal flasher to operate, WITH LEDS as turn signals you need flasher (electronic not thermal) designed to work with LEDS or to add load resistor...
http://c1.staticflickr.com/3/2502/38859 ... dbb6_o.jpg
http://c1.staticflickr.com/8/7432/87223 ... 5cb973.jpg
Sorry it does not display image as forum software/editor does not want to accept URL as a valid image...
Dale
Post by Marc » Wed Mar 29, 2017 3:41 pm
Decided to change bulbs on my 73 12volt Ghia to LED. Single contact bulbs for flashers and reversing no problem...
Robert
And yet almost everyone seems convinced that you had a flasher problem.
I guess when the only tool you have is a hammer, every problem looks like a nail :wink:
Dale M.
Post by Dale M. » Wed Mar 29, 2017 6:16 pm
Robert
Aaaah... I read it wrong like everyone else.... Its the tail lamp function that did not work NOT a turn signal problem...
All I can suggest is you put a little more contact pressure on tab that contacts bulb... Maybe polish both bulb and contact....
Dale
Post by Piledriver » Thu Mar 30, 2017 4:45 am
The socket/ground locating notches tend to corrode, where the little side nubs lock in//connect...
Its usually only pot metal (zinc alloy) even if chromed, it will corrode over time even if kept dry just from humidity
once you scrape them clean put a dab of silicone dielectric grease on everything to preclude further corrosion. (unless you can score the magic stuff the military uses these days, haven't looked if they sell it on ebay. Yet...)
Post by Marc » Thu Mar 30, 2017 3:57 pm
Bulbholders that are stamped sheetmetal are pretty easy to tweak in place with a small screwdriver to get them to grip the bulb better; a simple trick for the cast ones is to use a paper matchstick as a shim - they're laminated paper so you can peel them apart to make just the right thickness.
Post by Piledriver » Fri Jun 09, 2017 7:09 pm
For a simple graphic mansplaining connector lubrication, see https://www.nyelubricants.com/stuff/con ... _final.pdf
I admit, after decades of training and practice of "absolutely clean and dry" for electrical contacts, learning about using electrical connector lubricant feels kinda like discovering electrical contacts are are a million times more reliable if first covered in creamy peanut butter...
The ~WORST thing for reliable connections esp in a high vibration/humidity environment is clean and dry.
Pissing on it would be worse, but not by much. Peanut butter might actually work better.
ALWAYS using connector cleaner/lubricant/protectant is the new "correct" way.
This stuff is only $15/spray can, highly rated, and can be used for general corrosion control as well as electronics/electrical connectors.
https://pilotshq.com/zip-chem-cor-ban-5 ... 14769.html
Dale M.
Post by Dale M. » Sun Jun 11, 2017 8:47 am
When in work world (telecommunications) for 38 years we used NO-OX-ID (grease) on all mechanical or crimped power cable connection from #8 to 750,000 CM cable, and all connections to batteries and inter-cell connectors... IT was a requirement...
Still use it on batteries on personal vehicles, and if battery terminal are prepped correctly (clean and polished) there is absolutely no corrosion at batteries for life of battery... First thing I do when "new" vehicle comes home, is clean and prep battery cables/connectors (replace cables if necessary on used vehicles) .. Absolutely no problems with battery connections there after..
These replacement connectors absolutely will not be used on any of my vehicles as they are first source of any battery troubles which they are supposed to repair..
Dale
