6mm Allen Head Sump Nuts??
Moderator: sparkmaster1
sidemarkers
Post by sidemarkers » Sat Jul 08, 2017 2:21 pm
Bolting on my 1 1/2 deep sump and can't fit the nut on the stud that supports the pick-up tube.
Who makes an allen headed nut for a 6mm sump stud?
Re: 6mm Allen Head Sump Nuts??
Post by Ol'fogasaurus » Sat Jul 08, 2017 8:14 pm
https://www.bing.com/search?q=6mm+allen ... 48b53e795b
For example. Just be careful as the Allen head bolt does have a smaller contact surface area as compared to a Hex head bolt. I seem to remember that there are different sized heads for SAE fasteners but I am not that familiar to what is available in Metric sizes.
The URL I gave you is a general search list of sites available. I search 6mm "Allenhead" bolts; there should be a space but I got a blank search when I did the search that way. You might get a better search if you try the space in the word Allen Head than I did.
Post by Marc » Sun Jul 09, 2017 3:29 pm
If the problem is the stud being too short, I don't see how a different nut will help. Are you doing this in the car or do you have the engine on the bench/stand?
As a rule deep sumps require that all six studs be replaced with longer ones; the one that doubles as the pickup holddown has a washer and shakeproof nut above the tab on the pickup which is a bear to manipulate on an assembled engine, but it can be done with a modified 10mm box-end wrench.
Gene Berg made sumps with larger holes and special "longer nuts" that have an extended portion which reaches through to engage stock-length studs...makes installation much simpler but personally I prefer the classic "longer-stud" solution.
viewtopic.php?f=34&t=148583&p=1233615
Post by Ol'fogasaurus » Sun Jul 09, 2017 4:04 pm
My bad, I just read the first post and either missed the word "nut" or assumed he meant a bolt. :oops:
As far as I know there is no Allen head nut or any of the center located styles (such as Phillips, cross, 6-point/double triangle, etc.) in the head of the nut styles of fasteners; e.g., the hole for the bolt/stud would occupy the same area as the internal relief that the Allen nut driver would occupy.
The Gene Berg style of fastener sounds like some of the off-set spacer/centering style of nuts or centering styles of shims that I have seen in the standards books. I agree with Marc that replacing the stud with a longer one unless the object being clamped has the larger style of hole or counter bored stock hole based on the original fastener length.
Post by Marc » Sun Jul 09, 2017 7:59 pm
GB210NUT: Image
Post by Ol'fogasaurus » Sun Jul 09, 2017 8:19 pm
Yes, I have seen that nut design before but it is something we weren't allowed to use. They (the company and the FAA) are very particular on meeting hhig/tight standards. :roll:
If the mount has a hole for a larger this is one very good way of solving the problem.
sidemarkers
Post by sidemarkers » Mon Jul 10, 2017 4:17 pm
Thanks for the input guys! Since I just needed a single allen nut for the sump stud, I just made my own. If I could I'd post a pic, but it would likely take me longer to learn than installing the nut in my car!
Post by Marc » Tue Jul 11, 2017 10:31 am
Still not understanding just what it is you needed to replace; like Lee, I've never seen or even heard of an "allen nut". Did you take out the stud and replace it with a capscrew (Allen-head BOLT)? If so, what's holding the oil pump pickup down?
viewtopic.php?f=18&t=127818
sidemarkers
Post by sidemarkers » Tue Jul 11, 2017 9:34 pm
Thanks for the photo info. I got it all together, the nut I made worked very well for the difficult sump stud. I'm not sure if an allen nut is even a thing, but that's what I needed to get the last fastener on the sump. The rest of the fasteners are standard allen bolts.
