Hey all. I know during my months of research trying to build my FI setup, I can across several others looking for stock FI end castings to no avail. Seems CB got the hint and decided to put these back into production again.
http://www.cbperformance.com/product-p/7360.htm
Stock FI End Castings from CBPerformance
Moderator: Tom Notch
- kangaboy
'74 Standard- 1776T, MS3X3
'76 Westy- Stock 2.0L L-Jet
- ps2375
- kangaboy
Re: Stock FI End Castings from CBPerformance
The kit that Antonio sells is the Mexican Kit. The endcastings that CB sells is the original DP endcastings with the injector bungs in it. They discontinued it for a while.
- ps2375
not sure what the difference is.
- sideshow
- Contact:
The center chunk you want to use;
Carbureted beetle style --> CB end castings
L-Jet beetle style --> OEM steel end castings
Mexican FI --> MX end castings
Flexibility wise the carbureted intakes are the most common and diverse (options), followed by the dual IDF pattern.
