Something is not right with my Weber DCOE please help
Moderator: seabeebuggy
advinnie
Post by advinnie » Fri Jan 12, 2018 8:36 am
Hi all I have a Weber 40 dcoe carb on my turbo bug. Before Xmas it was working fine but now something has gone wrong. The problem is at idle there is a lot of fuel pouring out of the auxiliary venturi. As far as I’m a where fuel coming out of the auxiliary Venturi means the main jets are active?
If the main jets are active that means the progression holds have been uncovered ?
Is my thinking correct?
66brm
Re: Something is not right with my Weber DCOE please help
Post by 66brm » Fri Jan 12, 2018 8:48 am
What's your fuel pressure like? And check your float/needle and seat, may have crud in there letting excess fuel through
advinnie
Post by advinnie » Fri Jan 12, 2018 11:48 am
That’s what I was thinking so changed the needle valve and washer for a new one, reset the the floats 8.5mm & 15mm drop and the fuel pressure is set at 3psi
madmike
Post by madmike » Sat Jan 13, 2018 7:42 am
does sound like a piece of crap in the Inlet valve :roll: ? or the pressure went up? I've dropped the pressure to 2lbs before :wink:
advinnie
Post by advinnie » Sat Jan 13, 2018 8:35 am
The new inlet valve has sorted it, well let’s just say it’s all up and going again
madmike
Post by madmike » Sun Jan 14, 2018 6:40 am
8)
