fuel pump for FI
Moderator: Tom Notch
sandhopper
fuel pump for FI
Post by sandhopper » Fri Jul 27, 2018 7:13 pm
What fuel pump do I need to get for the CB EFI system ? The instructions says 45lbs
Can this be purchased at Auto Zone ? if so what car do I say I need it for ?
risk
Re: fuel pump for FI
Post by risk » Mon Jul 30, 2018 9:58 am
Have them look up a 1989 Ford F150. They use an external EFI pump. CARTER P74028
Just about any external fuel pump for EFI will work.
You will still need a regulator to achieve the 45 psi.
sideshow
Post by sideshow » Mon Jul 30, 2018 11:14 pm
That is the non-bosch version that fits the gas 2.9l 1986-88 fuel injected bronco2s, I also have never heard anything bad about them. I use one in my B2 with good success.
But in factory form they have a lift pump in the tank and a neat old school fuel filter (kind of a paper based mini system-1)
