102's
Hot Wheels
102's
Post by Hot Wheels »
Jake or charles,
Im going to put my pistons in tonight and had a couple questions before i complete the assembly. The rings appear to be pre gapped? What is the acceptable range before i need to file them?
Is the ring gap stagger the same as on a standard type four piston? 120 degree stagger.
Post by MASSIVE TYPE IV »
double check the ring gaps... Use the spec from JE included in the piston box... I run about .018 on the second ring and .016 on the top
dstar5000
Post by dstar5000 »
Jake, these Nickies?
That seems kinda tight for forged...
Don
Yep Nickies....
dstar5000
Post by dstar5000 »
Jake,
when you gonna have time to hook me up with a crank and rods to go
with the Annihilator cam I bought from ya?
My toes are itching to punch a gas pedal...
Don
whenever you got the $$$$$$$$$
dstar5000
Post by dstar5000 »
MASSIVE TYPE IV wrote:whenever you got the $$$$$$$$$
BUWAHAHAHAHAHAHAHAHAHAHAHA!!!
Drop me an email with a PRICE!
:D
I need to know how many *duckies* I have to save up!
8)
Prolly could have done it already, but bought a 911 shroud and a
pair of 45 DELLS!
They'll be OK with this cam, eh?
:shock:
Don
Hot Wheels
MASSIVE TYPE IV wrote:double check the ring gaps... Use the spec from JE included in the piston box... I run about .018 on the second ring and .016 on the top
Thanks, any concern with the oil ring? Seems pretty tight and one piece outer
thanks. On to the heads thisafternoon. check the valves and enlarge the head bore....
Hot Wheels
about .030 gap on the rsr one piece oil ring jake? having trouble finding a spec for that.
Yes, it is factory pre set..
Hot Wheels
mine are a lot tighter than that, gonna have to file them.
hmmn, let me look up some specs..
Hot Wheels
thanks,
Charles said they switched to JE rings on the later sets, set 0006 still came with the RSR rings. Crimson's probably did to.
Yep... I have only used two sets with the 3.8 RSR rings..
Hot Wheels
Any luck with an rsr spec? or do you think the .030 is ok? mine are at .004 as they come out of the wrapper. Too tight for my liking.
Locked
