Head temp sensor above or below the spark plug washer?
Moderator: Daniel G
BajaT4
Post by BajaT4 » Fri Jan 23, 2004 1:30 pm
Which way is better?
Mount between the plug and washer and I suppose you'd get the best sealing but the sensor spins with the plug.
Mount between the washer and the head and sealing isn't as good but the sensor is easily removed.
Billyisgr8
Post by Billyisgr8 » Fri Jan 23, 2004 1:41 pm
I did mine below the washer... It would have been a pain to remove the plugs with the sender above the washer.
Kevin
Post by MASSIVE TYPE IV » Fri Jan 23, 2004 2:04 pm
I remove the washer...
dstar5000
Post by dstar5000 » Fri Jan 23, 2004 2:37 pm
MASSIVE TYPE IV wrote:I remove the washer...
Only one out of three follows the directions on the box.......
:twisted:
Don
BajaT4
Post by BajaT4 » Fri Jan 23, 2004 3:00 pm
dstar5000 wrote:Only one out of three follows the directions on the box.......
I thought that was for wiping my hands when I was done with the install! :roll: Actually, I can't believe I missed that.
http://www.vdona.com/Tech%20Support/Aut ... 0Gauge.pdf
samcat
Post by samcat » Sat Jan 24, 2004 4:55 am
I also removed the washer.
In addition I used some copper grease to act as a kind of thermal interface... Helps the heat transfer more easily... So a more accurate/faster responding reading.
Cya,
Sam C
Guest
Post by Guest » Sat Jan 24, 2004 1:34 pm
I just tore down my 2lt. TI that the OP did not remove the washer on the plug also, it was the only chamber that the exhaust valve was not totally shot, but only due to a weak spark (well the spark was goods just too far inside the threads) JR
Alpine
Post by Alpine » Sat Jan 24, 2004 2:40 pm
Can someone provide a link to a picture of this temp sensor? Is it worth having on a 914?
Post by MASSIVE TYPE IV » Sat Jan 24, 2004 2:49 pm
Its the thermocouple for a CHT gauge.
EVERY aircooled car on the road needs a CHT gauge!
Wally
Post by Wally » Mon Jan 26, 2004 6:38 am
..and ideally 4 sensors: one under every spark plug!.. with a dash 4-way switch.
:D
Walter
BajaT4
Post by BajaT4 » Mon Jan 26, 2004 10:00 am
Wally wrote:..and ideally 4 sensors: one under every spark plug!.. with a dash 4-way switch.
...with a Westach 4 in 1 gauge!
Post by MASSIVE TYPE IV » Mon Jan 26, 2004 10:07 am
yep, I have 6 of those puppies....
Guest
Post by Guest » Wed Jan 28, 2004 5:48 pm
MASSIVE TYPE IV wrote:yep, I have 6 of those puppies....
You gotta flat 24 engine ?!?!?!?
Cya,
Sam C
Poor Realist
Post by Poor Realist » Wed Jan 28, 2004 6:16 pm
Neither - remove it. (it's a depth thing...)
Post by MASSIVE TYPE IV » Thu Jan 29, 2004 12:24 pm
One for each car...........
Locked
