These pictures represent two SCCA race seasons of extreme abuse, with most of this engine's life at 7000 rpm. Both cam and lifters showed NO MEASURABLE OR VISUAL WEAR!
Ceramics
Camshaft
The damn cam still has the moly spray lube on the lobes in alot of places!!
You can still feel the ridges in the cam from where it was machined. I ran my finger nail across the top of one of the lobes parallel to the cam and could feel that there was NO wear on the cam.
Seeing is believing.
Some times it does not matter if you see something or not because it is so awesome that you have a hard time grasping what you are looking at. All I know for sure is that I am glad this stuff is going in my engine.
I think I remember Jake mention that steel sleeving the lifter bore is REQUIRED but I don't see any mention of it on the LN engineering site unless you use the machine-in lightweight version? Could someone clarify?
Hmm.. that's interesting. Not only would I have to spend 450 bucks for the lifters, they will trash my case if I don't spend another $120 on sleeves? I wonder why Charles has it advertised as a "drop in" lifter? That sucks!
On the other hand, never having to worry about them would be groovy.
Sorry about that Mark. I'm in the process of re-doing the website as you've probably already noticed. I'll make note of the recommending sleeving of the case (if it's mag).
WOW those lifters dont look like they have any wear at all thats crazy, what about other engine parts made out of this ceramic composite, I don't know the metallurgical properties of this stuff like expansion rates and stuff but seeing as how the lifters didn't wear out @ all wouldn't they make good rings and bearings wouldn't they? or do the substances physical properties not lend it self to do such things? and the fact that the tooling to make somthing new would be extremly high
Alot of this technology is coming over from Formula 1. They are using it for valves and alot of other parts. I have seen retainers, keepers, valves and rocker arms made from it before and of course the lifters.
we are also doing some testing with ceramic coatings that reduce friction and wear for some applications, as well as "diamond like carbon coatings" (www.diamonex.com) for bearings and some other engine parts...
One test I want to do involves using a previously trashed lifter and regrinding it, then have some coatings used on it to see if it will still fail, or if the coating prevents it!
