Oil Pressure Sender with DTM and Mallory
Moderator: Daniel G
BajaT4
Post by BajaT4 » Wed Aug 04, 2004 11:21 am
There's no way the sender will fit in the stock location so I need to buy the flexible extension. Where is the best place to clamp the sender to?
Post by MASSIVE TYPE IV » Wed Aug 04, 2004 11:24 am
hmmn, I would say around the manifold area on the left bank.. Make sure you run a ground wire to the sender also, sometimes that hose does not give an adequate ground and it will read low pressure when its really not.
davygrvy
Post by davygrvy » Wed Aug 04, 2004 11:45 am
I'm using the extension kit from John
With a VDO sensor, lack of ground causes the meter to peg. I had that problem at first. An aligator clip has it working for me at the moment. Once I make a nice mounting bracket out of brass and braze it to the M10x1->AN adapter and bolt it to the compartment wall, I should be good.
BajaT4
Post by BajaT4 » Wed Aug 04, 2004 2:31 pm
yep, VDO used to make a relocation kit that included a nice galvanized metal clamp that you would bolt to a suitable ground but they don't anymore.
germansupplyscott
Post by germansupplyscott » Wed Aug 04, 2004 8:16 pm
JohnConnolly
Post by JohnConnolly » Wed Aug 04, 2004 9:44 pm
ours is stainless steel braided so doesn't require a ground due to a rubber hose.
John
Aircooled.Net Inc.
Post by MASSIVE TYPE IV » Wed Aug 04, 2004 10:07 pm
John,I have had to use another ground on a few of your hoses.. Not a big deal, though..
JohnConnolly
Post by JohnConnolly » Thu Aug 05, 2004 6:44 pm
perhaps, but BEATS RUBBER.
John
Aircooled.Net Inc.
davygrvy
Post by davygrvy » Thu Aug 05, 2004 7:01 pm
Give us a mounting bracket and your relocation kit is perfect, IMHO.
Post by MASSIVE TYPE IV » Thu Aug 05, 2004 7:30 pm
Yep, it does...
BajaT4
Post by BajaT4 » Thu Aug 05, 2004 9:13 pm
I've seen John's hose before so I think I'll stick with him. :shock: Sorry Punkin.
John, you've got an order.
JohnConnolly
Post by JohnConnolly » Thu Aug 05, 2004 10:46 pm
ok Davy, I'll work on that over the weekend
John
Aircooled.Net Inc.
dstar
Post by dstar » Fri Aug 06, 2004 10:41 am
BajaT4 wrote:I've seen John's hose before so I think I'll stick with him. :shock: ............
BUWAHAHAHAHAHAHHHHAHAHAHA!
Am I the only one amused?
8)
Don
JohnConnolly
Post by JohnConnolly » Fri Aug 06, 2004 11:07 am
I'd like to think my hose is superior to most. ;-)
John
Aircooled.Net Inc.
dstar
Post by dstar » Fri Aug 06, 2004 11:12 am
JohnConnolly wrote:I'd like to think my hose is superior to most. ;-)
John
Aircooled.Net Inc.
BUWAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA!
You're KILLIN me John!
Don
Locked
