My dynoresults
marko_j
My dynoresults
Post by marko_j »
My street beetle from finland.
Dynoresults using streetgasoline. (98okt)
blue thunder
Post by blue thunder »
Wow, did the dyno survive the punishment? 8)
Cool shroud!! What kind of fan do you use?
Looks like you have a serious dip at 2800 rpm, or did you lift the throttle?
Have you got some engine specs?
11.3@127mph at Brilon, Germany (unprepped track)
Turbo: the best blowjob money can buy
Assumption is the mother of all flip-ups......
panel
Post by panel »
That things CRAZY! What are the specs on that thing?
Billyisgr8
Post by Billyisgr8 »
looks like a wasser case
Kevin
marko_j
Post by marko_j »
Engine: WBX
Engine size: 2699cm
Compression: 8:1
Sylinders/Pistons: Deutz/wiseco 4"0,30
Crankshaft: Pug Pack 82 mm
Connection rods:Scat lenght 5,500 in
Case: WBX
Lifter: typ 1"pug pack light"
Sylinder heads: Autograft 910 intake flow 163cfm(313hv) 28"/ex122cfm(235hv)28"/0.551lift
Titanium Valves: 2.02 int/ 1.60"/0.551 lift
Camshaft: Engle FK89
Rockers: PugPagk 1,4:1 valve lift 14 mm (0,551 in)
Total Power: 550-600hp 1.5-1.7bar(22-25psi
Engine running 8000-8200rpm/1.7bar(30psi)/600nm
568nm torgue=14psi
479hp=18psiImage
Turbocharger 76mm("3)ex and 72mm(2.83" intake.
inside
James Buchan
Post by James Buchan »
WOW! :shock:
ToRy 70
Post by ToRy 70 »
Shazbot!
Rex Surewood
Post by Rex Surewood »
[speechless]
pointblank
Post by pointblank »
That is amazing, Yet you say it is your street beetle. and with the engine coming through the back seat how is that street-able?
JoeSumen
Re: My dynoresults
Post by JoeSumen »
[quote="marko_j"]My street beetle from finland.
marko,
clean work!.... ihme kuinka kauan se jälkisäädös kestää ainoastaan ihana aikaansaada ja edustava eksponentti !!!!!
Folks, this is a perfect example of when staged injectors are required...The non-linear parabolic output spikes lower in the rev range indicate something just isn't kosher....Now, the heads/valve sizes and camshaft certainly play a role in the dramatic near vertical curve at the mid/upper end, just as they do in reference to fuel atomizatation (or the lack of it) due to injector placement...Targeting the backside of the valves is absolutely crucial for acceptable off throttle, lower end performance. A substantially smaller lb/hr primary injector as close to the intake valve as possible with a set of secondary injectors anywhere is the preferred albeit costlier set up here..
Nonetheless...Good peak numbers and clean work marko...Hope your life insurance policy is up to date... :wink:
Joe
turbobug56
Post by turbobug56 »
Where is the cooling fan?
racelook
Post by racelook »
Holy mama!! Speechless
Wiebrand
ToRy 70
Post by ToRy 70 »
Those injectors are pretty up there. That is some insane fabbing though. Now you won't need those inadequate heater boxes. Nice!
panel
Post by panel »
turbobug56 wrote:Where is the cooling fan?
WBX meaning water boxer.(water cooled)
Joe vw
Post by Joe vw »
Nice car!
I see head fins though, is it an Oxy-boxer? Whats with the engine shrouding?
