Pics of the"Hybrid Heads" Len and I have been work
Moderator: Daniel G
Post by MASSIVE TYPE IV » Wed Jan 12, 2005 4:46 pm
These puppies are amazing! Look at that odd valve train and weird coatings on the valves.. :-)
If you look close you'll even see valve stem seals, something thats unheard of today but made possible by the friction reduction properties of the DLC coatings that you can see here. http://www.aircooledtechnology.com/coatings_2.htm
Its being assembled starting tomorrow and will be dynoed in the next two weeks....
Look here for more detailed pics
http://www.aircooledtechnology.com/r_d_hybrid.htm
These puppies are the next level of TIV development, all the best ideas from all the basic TIV head designs ever produced all compiled into one unit....
These heads are KICK ASS! Len out did himself on the work! Lookin to put this 2316 in the "200 club" on pump gas as a daily driver.
"Excellence through Research"
Last edited by MASSIVE TYPE IV on Wed Jan 12, 2005 4:53 pm, edited 2 times in total.
Rescue912
Post by Rescue912 » Wed Jan 12, 2005 4:51 pm
nice. someone's been a busy bee ...
Bugzlife
Post by Bugzlife » Wed Jan 12, 2005 5:00 pm
BEE-HIVE Vlve springs?
Post by MASSIVE TYPE IV » Wed Jan 12, 2005 5:18 pm
Not on those!
Them are "borrowed" from another very **nice** engine.. same with the retainers and valves...
Len did alot of research on these and alot of extra work on this initial pair to make it all work out..
It has Titanium pushrods, lightened ceramic lifters, lightened rockers and the works..
And now its gettin Nickies...
speedy57tub
Post by speedy57tub » Wed Jan 12, 2005 5:43 pm
What cores did he used for these heads? :shock: Nice work Len!!!!
Post by MASSIVE TYPE IV » Wed Jan 12, 2005 6:06 pm
Those were 2.0 vanagon new castings...
Post by Piledriver » Wed Jan 12, 2005 6:49 pm
New castings... from AMC.
Do they make a 1700 register new casting? Unfinished?
mrspunone
heads
Post by mrspunone » Wed Jan 12, 2005 6:50 pm
Damm I thought those were my heads LOL Jake you got mail
Dave_Darling
Post by Dave_Darling » Wed Jan 12, 2005 7:31 pm
AMC does make 1700 register head castings. You can get them bare or loaded. Hmm... Actually, the "bare" ones might still have guides and seats; I forget. (It's been 3 years since I saw their booth at the SEMA show and got the price list.)
--DD
Plastermaster
Post by Plastermaster » Wed Jan 12, 2005 8:42 pm
Len and Jake: Very nice work! Do they have the 7mm Xydene valve stems?
Ron
Post by MASSIVE TYPE IV » Wed Jan 12, 2005 9:08 pm
Those are the 7mm stemmed valves..
Wally
Post by Wally » Thu Jan 13, 2005 2:27 am
Very, very nice heads. Indeed impressive work, especially I like there is still quite a lot of meat around the exhaust port, which should make the head very long lasting, despite the porting work. Very gentle slope in the exhaust path: excellent!
They should flow very well indeed.
Are those 42x38 valves? The ratio exhaust/inlet valve seems a little more biased towards the exhaust than usual combo's judging the pics, but I could be wrong.
The remake of fins where the old sparkplug hole was, is also very beautifully done!
Kudos to Len!
Thanks,
Walter
Post by MASSIVE TYPE IV » Thu Jan 13, 2005 3:03 am
Yep, 42 x 38!
The 42 fed very well- Plenty! We were originally going 44 but we changed our minds mid stream..
Class 11 streeter
Post by Class 11 streeter » Thu Jan 13, 2005 9:31 pm
Any chance AMC would be interested in casting Len's improved design? (without the necessary "finish work" of course)
dstar
Post by dstar » Fri Jan 14, 2005 11:06 am
For $15,000 clams for the first one, they will!
:lol:
Then they are about $500 each head, if ordered in 100 count batches....
Then you gots about $1000 in finish machining and parts...
SO, you gots $1500 per head, AFTER the initial $15,000, invested per head.
I think Len can make you a set cheeper!
:wink:
Don
Locked
