Exhaust testing starts today!
Thats right...
We ended up being down for parts on a couple of builds today and through the end of the week due to waiting on some parts to get "Frozen"..
Brent and I decided tto pop the 2270 on the dyno and start the testing..
Should be finished by weeks end if we don't explode something..
First up is the A-1 so I can get it back to Tiger and he can get them all Jigged up and ready to be sold.
Get ready for a mass purchase on Feb 1!!!!!!
Last edited by MASSIVE TYPE IV on Tue Jan 25, 2005 4:58 pm, edited 1 time in total.
The engine had a couple of issues....
Shall we say LIFTERS! Didn't even make it through the first run before the chip detector in the main lube line lit up. Obviously my idea for this set of lifters wasn't a success..
I was trying to run a new lifter test at the same time as the exhaust tests, then pull it down afterward and see what was going on..
Its apart on the bench now, will be running again tomorrow morning with another set of lifters...
I will have all the tests with the A-1 done tomorrow, and possibly Turbo Thomas as well....
- Frallan
Its an aircraft part.
I came into contact with them working on Helicopters. We used them in the transmissions to detect gears/bearings starting to go bad. I plan on stocking them soon.
It is a very simple part that works exactly as you explain. This particular one provides a ground when the contacts are bridged by metallic particles that stick to it.
