Pics of the 914 spec DTM
Moderator: Daniel G
Post by MASSIVE TYPE IV » Wed Feb 02, 2005 10:58 pm
Here it is guys!
Its not pretty sitting there all naked and bare without it's Gelcoat on, BUT at this point it just has to function and be proven. It still didn't turn out too bad considering it wasn't made in a mold!
http://www.aircooledtechnology.com/r_d_914_dtm.htm
Nevermind those pics of engine parts- Charles goofed up when he loaded them in a jiffy for me today. (those are a newly designed piston for a wild chamber Len and I designed and a 66x100 bore size)
We finished the mock up over the weekend and its ready for the dyno next week!
This shroud is the first one and it is set up for guys with full external oil systems, full flow and accusumps- like my car. After I make this version work it will shed some light on what I need to modify to physically go further with to fit into the 914 and still utilize the factory oil cooler. I have two possibilities of that at the present.
The other design locates a small efficient cooler normally used externally in the sheetmetal just forward of the engine toward the cockpit of the 914. This version will blow air into a duct we are making now, through the sheetmetal and out the bottom where another duct will be that has a venturi effect to help pull air through the cooler even faster as speed increases!
Its amazing that I have gotten this far with it with everything else going on here!!!!!!!!
For those that are not on my list but would like to be email the Mad Scientist at productdevelopment@aircooledtechnology.com
Post by Piledriver » Wed Feb 02, 2005 11:49 pm
Gotta love the Hammerite on the valve covers....;-)
(Great stuff actually, I use it a lot)
Guest
Post by Guest » Thu Feb 03, 2005 12:24 am
Does that tunnel ram on the shroud work? pretty soon you won't even need the engine... the shroud will be the engine.
Post by MASSIVE TYPE IV » Thu Feb 03, 2005 1:18 am
Thats actually a sound supressor!
In a 914 the engine is right behind your head. I'm hoping this will enhance cooling AND make the fan quieter at the same time..
I'm gonna dyno it with and without the ring to see what it does temp and sound wise.,
70dragbug
Post by 70dragbug » Thu Feb 03, 2005 4:39 am
Another advantage of that "bellmouth" is it prevents turbulence caused by the fans suction,that way it gets a constant maximum of air.Jet engine Manufacturers use that in front of the engine on their Dyno Cell when they test their engines.Some Helicopters have them too.
70dragbug
Post by 70dragbug » Thu Feb 03, 2005 4:47 am
Oh nice work by the way Jake! I´ll bet you´ll see quite a drop in temperature,too.Your fan may spin a little faster because of the lack of turbulence and less resistance.
synthesisdv
Post by synthesisdv » Thu Feb 03, 2005 8:28 am
jake,
i'm making some oil cooler ducts from CF and FG. How did you mock that thing up without molds? I was going to just join some flat pieces and then fill and sand and then lay up a couple more layers.
shambly
Post by shambly » Thu Feb 03, 2005 8:42 am
Jake,
Is that alternator backing plate part 16512 in your new store?
Would compliment my CF DTM much more than the stock backing plate it has now, so will order one if it is.
Simon
Mr.Spunone
DTM
Post by Mr.Spunone » Thu Feb 03, 2005 9:05 am
Very cool.Looks kind of scary all put togeather hope it tests well .Still waitin on a sketch for the dyno LOL :shock:
Racer Chris
Post by Racer Chris » Thu Feb 03, 2005 9:33 am
Thats way cool man!
If we're gonna test it on my race engine we'll have to drastically modify my carb linkage.
You'll see soon enough.
JmuRiz
Post by JmuRiz » Thu Feb 03, 2005 9:56 am
Looks cool (har har). Can't wait to see how cool that 2316 beast runs with nickies and that DTM. :lol:
speedy57tub
Re: Pics of the 914 spec DTM
Post by speedy57tub » Thu Feb 03, 2005 10:05 am
MASSIVE TYPE IV wrote: Its amazing that I have gotten this far with it with everything else going on here!!!!!!!!
Yup, making molds is a pain in the arse and I did it almost two years ago when I did my own Type I 911 shroud. After many trial and errors, I got decent results but would I do it again, most likely not :x since it is way too much work! Jake, once again---super nice job. This design could be a possibility for some of the VW based kitcars/replicas! :P
Post by MASSIVE TYPE IV » Thu Feb 03, 2005 10:36 am
I have two more possibilities for the shroud as well. This one is basically for guys that have extensive oil systems with huge coolers and don't need the stocker. (like Chris)
The two others will be fitted after the engine is in the car, then I'll remove it and dyno it again since fit is the main challenge here and not design.
davygrvy
Post by davygrvy » Thu Feb 03, 2005 10:50 am
Hmm... I wouldn't mind not having the T4 oil cooler in my beetle's engine.. maybe next time when I'm ready to swap to red kevlar :)
Guest
Post by Guest » Thu Feb 03, 2005 1:26 pm
Will there be a version that seals off the sides and rear or the compartment as well as the front mold with a cooler and ducting. My teener just started drooling.
Locked
