Web 121/125?
Moderator: Daniel G
prerunner1499
Web 121/125?
Post by prerunner1499 » Thu Feb 03, 2005 2:23 pm
What if any info does ayone have on this cam?
Im trying to decide on a cam to go into a 2187. I want a motor with good torque curve, and will make power in all rpm ranges. Will be run in a light baja bug. It will see 5500rpm+ from time to time :-)
I DONT want a motor that only makes power from 3k and up. Heads will be CNC 044 mag plus with a little more messaging by me.
Carbs, either duals, single 44-48 weber MX if they fit under my cage, or CB efi.
Post by MASSIVE TYPE IV » Thu Feb 03, 2005 2:42 pm
Torque monster with a nasty powerband ...
The 122/125 is better for offroad though, depending on headwork
prerunner1499
Post by prerunner1499 » Thu Feb 03, 2005 4:00 pm
OOPs, Actually thats the one I was referring too. 122/125 compared to way an engle 120 or 130.
NO_H2O
Post by NO_H2O » Thu Feb 03, 2005 4:35 pm
I have a Web Cam 122/125 for my 2275 type 1. It has a very nice low end grunt and my engine has a very flat torque curve from 2500 to 5000. I don't think you will get close to it with a 120 or 130 brand X cam.
prerunner1499
Post by prerunner1499 » Thu Feb 03, 2005 5:44 pm
NO_H2O wrote:I have a Web Cam 122/125 for my 2275 type 1. It has a very nice low end grunt and my engine has a very flat torque curve from 2500 to 5000. I don't think you will get close to it with a 120 or 130 brand X cam.
are you using 1:1 rockers with that cam?
Post by MASSIVE TYPE IV » Thu Feb 03, 2005 7:23 pm
Yes, No H20 built his engine here at my shop.
Due to ramp rate this cam is ONLY compatible with a stock rocker
NO_H2O
Post by NO_H2O » Thu Feb 03, 2005 7:56 pm
Yes,,,,,what Jake said. Stock rockers with old school swivel adjusters.
yeahmag
Post by yeahmag » Fri Feb 04, 2005 3:38 pm
I have it in my 2276 and really like it. It reguarly sees 6500+ RPM. It's a crazy fast car with the close ratio box I have in it now.
-Aaron
prerunner1499
Post by prerunner1499 » Fri Feb 04, 2005 4:16 pm
Ok now next?
Is this cam warrantied by Web if I use Scat lub a lobe lifters?
I would love to use the ceramic lifters but thats a few banjamins over my budget $$$ LOL
Clatter
Post by Clatter » Fri Feb 04, 2005 4:20 pm
Thinking of running the 121/125 in my 1915...
Weber 44s
1 & 5/8" exhaust.
I have professional (oval) ported and polished 40 x 35.5 heads.
Would this be too much cam for a smaller setup like this?
Don't really mind the motor being a tempramental, but it would be driven on the street...
- Doug Ellsworth
yeahmag
Post by yeahmag » Fri Feb 04, 2005 4:26 pm
Don't know too many people running this cam, so Jake will probably chime in. But for reference, my car idles like a stocker and is totally streetable and nasty all at the same time.
I personally think you couldn't go wrong with this cam in almost an displacement motor. It's a very forgiving cam.
-Aaron
NO_H2O
Post by NO_H2O » Fri Feb 04, 2005 6:50 pm
prerunner1499 wrote:Ok now next?
I used the SLR surfaced Scat lifters from www.aircooled.net.
Flow
Post by Flow » Sat Feb 05, 2005 10:12 pm
If all other factors constant, what is the difference between the output curve characteristic of 121/125 and that of 121. Would it be both have the same maximun HP but at different rpm? Would the 121/125 have higher torque at low rpm range and flatter torque curve than the 121? Which one is better for road racing or track day events?
farmer
Post by farmer » Sun Feb 13, 2005 6:02 pm
The split one will produce more torque at a slightly lower rpm.
T.
Flow
Post by Flow » Thu Feb 17, 2005 11:13 am
Would CB's 044 cnc round port be too small for 121/125? The engine will be 1914 with dual weber 44.
Locked
