A-1 installed pics in Ghia...Excuse the Rust :D
Moderator: Daniel G
Ephry73
Post by Ephry73 » Wed Apr 06, 2005 6:59 pm
http://pg.photos.yahoo.com/ph/kateko69/ ... d8&.src=ph
The other pics are here(Also posted new ones too):
http://pg.photos.yahoo.com/ph/kateko69/ ... /my_photos
Hope this helps. As you can see, there is plenty of room to move the collector angle up a few degrees( I'll say about 10*) to give more ground clearance. Also, the muffler could be angled up and rotated on its axis a few degrees, and give even more clearance, without sacrificing power, or design.
ALso notice the sanding done to clear pipes, and make them able to slide in their corresponding bores.
Ephry
P.S. Jake, maybe you can tell Tiger.
P.S.S The oil is WD-40 I used to clean the pipes
R2.0
Post by R2.0 » Wed Apr 06, 2005 8:56 pm
What have you done with your old system? I'm interested, and local - Gaithersburg.
Ephry73
Post by Ephry73 » Wed Apr 06, 2005 10:44 pm
I have it in the kitchen. I was going to clean it up, paint it and sale it all.
Ephry
R2.0
Post by R2.0 » Thu Apr 07, 2005 8:18 am
Forgot to ask - square or oval port?
Ephry73
Post by Ephry73 » Thu Apr 07, 2005 9:00 am
Oval. The head pipes are quite nice actually, since they use stock flanges, which in my opinion offer the best sealing possible. I was not going to get rid of those, but I have too many parts at home, waiting to get sold. Anything else you may need?
Ephry
somordha
Post by somordha » Thu Apr 07, 2005 9:14 am
Ephry73,
It looks great. Can't wait to get the engine kit and exhaust installed in my ghia.
Do you happen to have a photo of the back end of your ghia with the new exhaust installed similar to picture 3 on your your Yahoo photos? I'd love to see a photo if you have one.
Thanks,
Jim
Ephry73
Post by Ephry73 » Thu Apr 07, 2005 9:26 am
You mean like a zoom out shot? I can get one by tomorrow. I need to go to get an apraisal on rust repair for the car. Where my car is parked now I cannot get too far, or get good light. I will definitely get that done tomorrow. There's good ground clearance for sure. Like I said, for us Ghia owners, a different collector pitch and muffler angle will be incredibly better. Also, the muffle rpipe sticks back considerably, a la Cal-look. keep your rear bumper, and you'll be fine.
Ephry
R2.0
Post by R2.0 » Thu Apr 07, 2005 10:44 am
Ephry73 wrote:Oval. The head pipes are quite nice actually, since they use stock flanges, which in my opinion offer the best sealing possible. I was not going to get rid of those, but I have too many parts at home, waiting to get sold. Anything else you may need?
Ephry
Rats - I have square ports.
Basically, I need everything from the head on out. For that matter, I need a bunch of other stuff as well, but I'm just cherry picking now.
Ephry73
Post by Ephry73 » Thu Apr 07, 2005 12:05 pm
I have a bunch of oval port heads you can use( two actually) in the two litter range. :D
Ephry
DaveB
Post by DaveB » Fri Apr 08, 2005 10:55 pm
Hey Ephry
Would take a rought measurement. if you have the time, from the pulley out to the collector? I'm putting mine in a Splitwindow Bus and have been wonder how far out pass the bumper it's going to stick.
Dave
Ephry73
Post by Ephry73 » Sat Apr 09, 2005 11:42 am
I will try to get the measurements s follows(remember, the system is installed in a Ghia)
-From collecto merge to collector opening
-Between pulley and collector merge
-from collector merge to first radial bend of muffler pipe
Hope that helps ya.
Pics I'm still trying to get
Ephry
DaveB
Post by DaveB » Sun Apr 10, 2005 7:59 pm
That would be great
DaveB
Post by DaveB » Mon Apr 11, 2005 9:57 pm
Have time for the measurements?
Ephry73
Post by Ephry73 » Tue Apr 12, 2005 7:42 pm
Sorry about the late response. I have been busy and have not been able to get the measurements yet. I will post them tomorrow.
Ephry
Ephry73
Post by Ephry73 » Wed Apr 13, 2005 10:05 pm
Ok, here are the numbers. Sorry about the delay. It's been one of those weeks.
from collector bend, to collector opening, 10.25"
from collector merge, to radial bend of muffler pipe, 16.5"
from pulley/crank bolt centerline, to top of collector, 3.5"
from edge of case, just below the pulley, to collector merge, 3.5"
between the oil filter and the #3#4 pipes, 1.25"
Ephry
Locked
