Fuel tank sender unit
Discuss with fans and owners of the most luxurious aircooled sedan/wagon that VW ever made, the VW 411/412. Official forum of Tom's Type 4 Corner.
jonnyrock66
Post by jonnyrock66 » Thu Aug 05, 2021 4:32 pm
Hi all.
1970 vw 411LE variant.
Got a siezed/broken fuel tank sender unit. Cylinder type. What is everyone using as a replacement and what is the correct cylinder length for a 411le ?
Think my broken one is off a beetle. very short.
Cheers Jon
dawie
Re: Fuel tank sender unit
Post by dawie » Thu Aug 19, 2021 5:54 am
Measured a 411/412 tube- type fuel sender. Length bottom to mounting surface- 285mm.
Also measured inside tank. Replacement sender should be no longer than original, otherwise it wo'nt fit.
Sender marked VDO and numbers 21/34. No idea what the makings stand for.
Bruce.m
Post by Bruce.m » Thu Aug 19, 2021 4:23 pm
Check vdo motorsport tank sensors.
Available in lots of lengths and the mounting plate is the old generic size which might be the size for a type4.
