Looking for brake light switch connectors for my 1972
Ghia. It’s a plastic piece the pushes onto the switch for
Power and brake light
Brake light switch connector
Re: Brake light switch connector
Another issue is replacing the shifter bushing.
I replaced the bushing and trying to push the shift rod past new bushing and found it amazingly hard to do. So do I just apply pressure of tap it with a hammer?all good and lubed.
- FJCamper
You must be missing the factory connector. I've never been able to find one, Just splice female connectors onto your wires. Also, the shifter bushing is a really tight fit. Muscle it in without damaging the bushing.
