Swing axles
Bunky67
Swing axles
Post by Bunky67 » Wed Sep 02, 2020 5:30 am
I broke an axle on my drag car (swing axle 26 11/16 ) and I'm not able to find a pair of sway a ways and don't want to spend the money for the EmpI ones. And I'm nervous about using a used axle not knowing what side it came from.
So does anyone know of a source for new stock axles?
Bruce2
Re: Swing axles
Post by Bruce2 » Wed Sep 02, 2020 8:19 am
You can always tell which side an axle was used on by the wear on the spades.
Stock axles have no place in a drag car.
Re: Swing axles
Post by Ol'fogasaurus » Wed Sep 02, 2020 10:33 am
So true and for so many reasons mostly safety for you and others!
Bunky67
Re: Swing axles
Post by Bunky67 » Wed Sep 02, 2020 10:36 am
I agree I'm only running a 1915 with a small turbo and street tires. So do now stock are ok. And like I said If I could find some sway a ways they would be going in. But no luck so far and don't feel like spending twice the money on EmpI that probably aren't much better than stock.
Re: Swing axles
Post by Ol'fogasaurus » Wed Sep 02, 2020 11:03 am
https://www.racereadyproducts.com/axles ... irs-axles/
I knew they were expensive but didn't realize that they had gotten this expensive. Still... for your and your cars safety plus, maybe, the safety for others I would start a savings account (no insult intended). I've seen what broken axles can cause at launch or even down the track (street :shock: ) breakage in cars causing a swerve to one direction or the other. I've even had to dodge a 4-speed trans when sitting watching the races at the finish line (found out later that the starter decided to engage. This was back in the old days... maybe in the late or early 60's but the unexpected can happen.
