Going from 2332 draw thru to 2.8 blow thru efi
- vwfye
Going to measure vs the current hole to see what mods are needed. Flywheel for the swap is installed.
From
From
Re: Going from 2332 draw thru to 2.8 blow thru efi
is that a vr6? is it the 12 valve or 24 valve version?
- vwfye
It is a 12v vr6
- vwfye
Looks like i have some more go fast parts coming this weekend.
- panel
What's it going into ?
- vwfye
1964 mid-engine notchback.
- panel
Going NA or turbo ?
- vwfye
- vwfye
Still working on the space the vr6 will drop in to.
- vwfye
I am still collecting parts. The SRI kntake should be here Wednesday. The harness/ecu is the part that will be some time, as I need the $ to get the Lugtronic stand alone system.
