The car is a 69 Bug, and is completely stock. I sold the freshly built (by me) 1641 to finance this conversion, and the money ended up paying for the adapter kit and the carb setup. I'll try to give a total cost of the conversion when I get it running, so others can see what it costs. If you already have a decent clutch setup, a good pair of dual carbs, and can scrounge around for parts, you may end up spending less. I am starting with a completely stock car.
First, the cooling system: I am using a 'Scirocco style' double pass radiator from Afco, mounted in the spare tire well. It is a very nice piece, is all aluminum, and is dual core. The capacity looks very large. Both the inlet and outlet are on the passenger side. It is mounted on a cradle setup made of 1/8" strap steel, and sits on foam rubber cushions. The top of the radiator is held by a couple U shaped brackets. The fan is a pusher style from a late-90s Saab 9-5. The motor on this thing is huge, and it seems to push enough air, so I'm hoping it does alright with our 110 degree summers here in Vegas. I may end up building a bigger 'scoop' under the nose if the current one doesn't direct enough air through the rad. I have a temporary fan shroud made of cardboard that I am going to use until I make sure the design is going to work. If the design is sound, I'll make it from aluminum.
The coolant travels from front to rear via 1 1/2" aluminized steel exhaust tubing. I towed the car to a local muffler shop and had the pipes bent up. They hug the floor as closely as possible, and run along the edge of the pan, under the heater channels. If I had to do it over again, I would run the pipes down the center of the car, as it would save a good 6-8 ft of piping.
Anyway, on to the pics!
No going back now! The spare tire well is cut out...
The 'cage' of strap steel. The radiator leans back a bit at the top, as much as is possible without interfering with the steering box.
Here is the radiator and fan mounted...
More to come...
Nick
