[*]1776
W110
Stock sized valved heads
009
Dual weber 36
( 28vents
55 idles
115 mains
F11 emulsion
180 airs
Vw earlybay
Vintage speed exhaust
I have been reading the aircooled.net page over
Im uk
What result have everyone been getting
So i buy the jets
Basically save me from spending x amount on jets that wont be anywhere near what i will need
I understand that not all are the same
Cheers
1776 vw wideband help
- V8Nate
Re: 1776 vw wideband help
I would recommend buying some jet drills/reamers to drill your jets out to get you close then buy sized jets later if you would like. There are more experienced people here that can get you close on jet size
Go watch some of the you-tube videos of “Motor7710”. He covers typical jet issues, how to solder & drill jets & tips about the poor quality bearings in Weber copies.
Along with the usual jet guides that should give you some food for thought
