Going under the knife
- Max Welton
Re: Going under the knife
Are type-3 66 end castings different from type-1 end castings?
Max
Max
Axle end castings, right? No idea, pictures might allow a lookup...
- Max Welton
My local guy says they are the same.
Max
Max
Re: the folding work supports, harbor freight #38778
https://www.harborfreight.com/200-lb-ca ... c_sept2020
- Max Welton
3x
Max
Max
- Max Welton
The reconstruction begins ...
Max
Max
Thanks for the first and second pix of the pan. Never seen one of the later pans before so I could notice the similarities and differences between the bug and the later pans.
Lookin' good!
Lookin' good!
- Max Welton
First time I've heard a 67 described as "later".
Max
Max
My short wheel base green buggy is registered as a '63... snot!
Consider 73 model seat rails etc, much, much safer if hit from rear.
The official vw fix is ugly and renders the seats non adjustable.
You could probably use mk1/2 or 3 rail setups, I suspect those parts are still available.
That may be the only beautiful pan I have ever seen///
- Max Welton
Ooh ... I found an error.
Max
Max
- Max Welton
I have a question about heat control cables. The rear seat pedestal (if that's the correct name for it) was trashed so Vega had to create a new one.
I note that there is a metal tube on the left but clips for the right control. Is this correct? Could someone show me what it looks like all hooked up?
Max
Max
- Max Welton
Believe it or not it's snowing here and below freezing. Yesterday it was close to 90 degrees F.
The barn is ... unheated.
Max
Max
- Max Welton
That took longer than it should have. But the beam is attached.
Max
Max
