I want to do this!
Need help installing a stereo or other interior item? Come on in!
Lew
I want to do this!
Post by Lew » Wed Feb 24, 2010 4:29 pm
I ripped out my original white headliner the other day and I want to do what was done in the 69 that's pictured. However my car a 72 standard has clips on the door post, and along the upper doors edge on my car that the orignial headliner tied into.
The 69 pictured has grey commercial carpet from Pep Boys in the ceiling. The car was built as a Cal Look and looked terrific. I saw this car in this years Winter VW Jam in Daytona, but the second owner did not do the body work, so he was not sure about it having the clips. I don't know if the 69's had clips for the headliner, if they did they were removed from his car and smoothed over with body filler possibly, and that's most likely what I am going to do. Anyone do something like this? :)
Re: I want to do this!
Post by david58 » Wed Feb 24, 2010 5:59 pm
Interesting. :D
helowrench
Post by helowrench » Thu Feb 25, 2010 8:53 am
david58 wrote:Interesting. :D
My thoughts exactly,
I cannot find anything that I dislike about it, just a concept that I had not thought of.
Qurtys Lyn
Post by Qurtys Lyn » Fri Mar 12, 2010 2:14 pm
I like, that would be a really nice custom job.
Fusername's evil twin
'72 Std Beetle - 1641 CC
BRAT Motorsports #936
doc
Site Admin
Post by doc » Fri Mar 12, 2010 5:47 pm
Just in time! Trying to decide on interior now.
doc
Lew
Post by Lew » Sat Mar 13, 2010 12:16 am
I have already made up my mind. :D I am going this route, and I have the perfect piece of carpet. In my opinion it's a much cleaner look and you never have to worry about tearing your original headliner or keeping it clean. The key here is making sure you use the proper adhesive to hold you material in place. I had much rather be doing a little sanding to make ready for paint, than working overhead with padding, headliner bows, trimming and tucking here and there. :roll: You had to see Paul's car to really appreciate the look. :)
AntLockyer
Post by AntLockyer » Mon Mar 15, 2010 8:50 am
My standard model '67 has just the centre piece of headliner like the one you show. This was how they came from the factory (only with normal material ratehr than carpet).
Lew
Post by Lew » Mon Mar 15, 2010 12:44 pm
Can you post some pictures? :)
BAJA-IT
Post by BAJA-IT » Tue Mar 16, 2010 11:09 am
Looks like they cut the tabs off the B piller and used a pinch weld molding (the same stuff used on the rear side windows when you have pop out windows) to finish off the seam. Above the door it looks like they cut the headliner tabs off (drill out the spot welds) and finish sanding for paint.
This would work good for an Off Road car like a Baja or class 11 look.
AntLockyer
Post by AntLockyer » Tue Mar 16, 2010 12:47 pm
Lew wrote:Can you post some pictures? :)
I'll take some when I get a chance.
Lew
Post by Lew » Fri Apr 02, 2010 5:49 pm
This AM I jumped inside the car were it was nice and hot, at least I was in the shade. I started removing the headliner clips on the door post and those above the door. Using some pliers I bent the tabs on the door post back and forth till they broke off clean. My flap disc removed the small edges that were left. On the top I was able to remove the strip by using a piece of wood I cut at a angle and placing it next to the clip and pulling against the wood with my channel locks snapping the strip from the spot welds. The strip came off nice and clean. Without the wood you will bend up the surface metal. The pressure against the wood distributes the forces over a larger area preventing the metal from caving in.
I will touch up the spot welds with the flap disc and be ready for a little surfacing compound, some sanding, then primer.
Lew
Post by Lew » Tue Apr 06, 2010 5:33 pm
I sure would like to see a picture of your headliner? Thanks! :)
67 Type-1
Post by 67 Type-1 » Thu May 06, 2010 2:34 pm
That is pretty clean looking.You could fill in the seams for a smoother look,I wonder if the carpet would stay glued to a layer of something like Dynamat Ultra sound deadner/insulation.
That would help keep it cooler and quieter inside.Yea,I think I like this idea,allows you to show off more paint work inside too.I have a 67 Export Model,I guess you could call it a Deluxe Model.It has the full headliner.
(o\_|_/o)
Lew
Post by Lew » Thu May 06, 2010 4:31 pm
I spoke with the tech at Fatmat.com when ordering my roll, and using adhesive over the fatmat will hold coverings in place. However the cocoa mat carpet I am going to use in the top will be held in place with adhesive and most like glued push pins. I plan to use a 1" wide finished Mahogany bows across from one side to the other space proportionally. Should work out OK. That's my idea at this point :) As for filling in the seams, I thought about it, but believe me it's a lot of work just getting the areas where you removed the clip and filled and smoothed out where it looks perfect. I decided to not go that route and keep it with the look of seperation. Your choice if you want that look and all the hard work it would take.
Lew
Post by Lew » Thu May 06, 2010 4:45 pm
AntLockyer can you get a picture of your headliner anytime soon. Some and me expecially would like to see it. Thanks! :)
