Speedo delema
Need help installing a stereo or other interior item? Come on in!
ouvw2
Speedo delema
Post by ouvw2 » Sun Jan 20, 2013 8:01 pm
I have a small problem that i need help with. I dropped my bug using cb drop spindels. after installing them i realized that there is no provision for the speedo cable, not that it would fit because of the arms arms are in the way. what did you guys do for a speedo after doing this. I have a cool 914 speedo I would like to keep. any ideas.
Randy
Re: Speedo delema
Post by Piledriver » Tue Jan 22, 2013 6:43 pm
Strange, I installed CB drop spindles on my 68 and it still had a speedo cable...
Check the US driver side spindle?
If RHD you may need to make up a custom cable, if rhd setup uses the r side spindle..
The longer a vehicle rests on jackstands,the more likely it is to remain that way...
ouvw2
Re: Speedo delema
Post by ouvw2 » Sat Jan 26, 2013 3:19 pm
i ve decieded to just use the speedo down load on my cell until I can figure this out. thanks
Max Welton
Re: Speedo delema
Post by Max Welton » Sat Jan 26, 2013 5:47 pm
I have seen GPS speedometers for such things as marine applications.
Max
