MadMike's 'Casper' 76 bug
Re: My latest ride
Air filter is on, a bit gaudy but I'll get use to it stickin out like a 'sore Thumb'
New turbo haulass too even at 12 lbs ,seems to have 'More" then the ebay one at 15 or so ,LOL,, wish I had a dyno
- Schweg
Re: My latest ride
Is the air filter any less in your face then the turbo?
- buguy
Re: My latest ride
I like it! Although I'd cut the extra off of the carb stud.
Re: My latest ride
Thanks, as for the stud you would think K&N would of suppeyed the bolt for $94
Re: My latest ride
well the Bug is running purdy good , I can't use the A/F gauge cuz the dump pipe needs a bung
took a nice drive yesterday to the next town , moose club has a nice little car show but i didn't stay,
bugs oil temp got up to 230* switched on the fan to the cooler came back to 215* but it was 92* I'm not worried about it
With this new air filter I can actually hear the secondary on the Quick fuel opening up so far 12 lbs or so, lifts this thing in 1st 2nd and 3rd ,,didn't need to stay 'in it' for 4th
new tires helped I must of been boosting a lot,(half a dozen times at least) cuz it used a couple gallons of gas
- buguy
Re: My latest ride
Seems like I read oil temps should be in the 230-260 range? I assume to burn off any moisture?
Re: My latest ride
I like 180*-212*,,,, and 215* is hot for up here , plus I don't need to change the oil as often,, run them hot and the oil breaks down
I'm swapping back to the t3/t4, not because the t4 don't work, but I need to see the a/r gauge I'm being anal I guess I seem to have gotten some water or crap/dirt, from the gas station, started bucking at lower rpm's , and that gauge would of helped me figure it out
Re: My latest ride
A/f i was thinking air fuel ratio so out came a/r
Re: My latest ride
all back together with the old/new t3/t4 turbo, boost comes on way quicker can't really tell much diff.in the power/torque/put your a$$ backintheseat Had some oil in the intake when I removed the t4 , but only seen smoke once when I came off boost,, strange , I was told it was rebuilt,notice on my test drive,, oil must of fouled some plugs cus it started to 'Break up' /Miss when I got on it,, did that twice,, third time it clear up and ran GREAT I want to Race on the 12th at Our Michigan 'Bug Run"
- buguy
Re: My latest ride
Whenever I've had oil in the intake it's when the turbo seal was bad.
Re: My latest ride
Good news ,,the guy I got it from offered to check it out
Re: My latest ride
testing for the up coming race and cracked a cylinder and lifted head ,, noticed a leak only after boosting ,, one tiny drop when not
- buguy
Re: My latest ride
Gonna be able to get it going in time?
