New guy, new build
Re: New guy, new build
Post by Piledriver » Sun May 09, 2021 4:32 pm
Forgot you were running ms2, heres my tune for same car ms2 + ms3x, plugs into ms3 harness, I can swap back and forth ms2/ms3.
ms2-pre3.4B10_2021-05-09_16.31.49.tsproj.zip
The longer a vehicle rests on jackstands,the more likely it is to remain that way...
chriswillrise
Post by chriswillrise » Sun May 09, 2021 9:17 pm
ok so I switched to a long db9 cable and connected the db9 to USB adapter directly into the laptop. Just did a 10 minute idle and revving in my garage with no disconnects! I also turned on the noise filter
Post by Piledriver » Mon May 10, 2021 4:45 am
Hopefully you also opened the garage door!!!
My neighbors likely love me, too./.
chriswillrise
Post by chriswillrise » Mon May 10, 2021 7:27 am
I’m sure mine hate me 😂 but the car is still up on jack stands so I can’t take it anywhere to “tune”
buguy
Post by buguy » Mon May 10, 2021 5:37 pm
Oh yeah. Try firing it up with a 1' long 3" open exhaust at 5:30 am. Make all kinds of new freinds!
chriswillrise
Post by chriswillrise » Mon May 10, 2021 9:34 pm
This is me 😂😂
Clonebug
Post by Clonebug » Mon May 10, 2021 10:46 pm
I fire mine up every morning at 6:15 with a 2 ft. long 2.5 inch exhaust......and just to let them know I'm heading to work I go out at 23 mph and 2300 rpm all the way out the development......got to let it warm up you know....... :wink: 8)
chriswillrise
Post by chriswillrise » Mon May 10, 2021 10:49 pm
Quick question, how do I get my tach to work? I see a pull-up resistor method? Are there tachs that work with the 5v signal MS sends out?
Post by Piledriver » Tue May 11, 2021 10:51 am
Most aftermarket tachs will work with logic signal/5v pulldown signals. try that first.
If that doesn't work you get to add stuff to your proto area... the transistor/relay coil setup should work with ~any tach.
xzener
Post by xzener » Tue May 11, 2021 4:29 pm
I just wired up a relay to mimic a coil to run to my tach. This method only uses pins 85 and 86 (coil). You can open up the relay and dismantle the switch part of the relay to get rid of the clicking. It clicks every time it passes TDC.
Boost is contagious.
chriswillrise
Post by chriswillrise » Sat May 15, 2021 1:41 pm
Got the tach to work now I'm just having a guy make me up a manifold for my TB with a throttle stop and a holder for the throttle cable.
I seriously cant thank all you guys who have helped me enough. I would've never taken on going EFI without this page and help from you all. Hell, piledriver has been helping me since I started this project off and on for like 4 years.
Once the manifold is done in a few days I should be able to put the car on the ground and start driving!
chriswillrise
Post by chriswillrise » Tue May 18, 2021 1:17 pm
Update.
I dropped a dizzy drive shim into the motor 😩
buguy
Post by buguy » Tue May 18, 2021 6:48 pm
Those are pretty big. Have you pulled the dizzy and gone fishing?
chriswillrise
Post by chriswillrise » Tue May 18, 2021 10:51 pm
Yeah but there is no damn room around the cam gear
bug66
Post by bug66 » Wed May 19, 2021 3:01 am
Pulled the oil pump?
2165cc on a Borg Warner S257 SXE, DTA S60 on E85.
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
