Land Speed 1915 Turbo build
- WickedWagens
I never got to finish the EFI turbo setup for my Ghia that I started years ago. I am now racing in a "classic" category at Bonneville which allows no electronics. I want to switch from the normally aspirated classes that I raced in last year and go to the turbo class. I have a displacement limit of 122.9 cu in. For this year I chose a 1915 cc for what I thought would be an easy straight forward build. It is starting to get interesting. Here is what I have so far.
New AS-41 case
DPR 69mm crank chevy/buick journal
I'm looking at 3/8" ARP bolt 5.6" H-beam rods
The cam is a R304 from Shag @ SL-1 racing .521 lift 304 duration
94mm AA True Forged pistons and cylinders
AC.net revmaster 049 L6T heads
RLR 4 barrel drawthrough carb
I'll get some pictures posted as I start to assemble.
New AS-41 case
1968 Karmann Ghia land speed
G/CFALT 106.643 MPH G/CGALT 113.131 MPH
G/CBGALT 169.462 MPH G/CBFALT 146.715 MPH
G/CBGC 158.242 MPH H/CBGC 94.334 MPH
H/CPRO 93.383 MPH H/CBFALT 101.282 MPH
H/CBGALT 120.591 MPH
Top Speed 174.2 MPH
Top Speed 174.2 MPH
- petew
Re: Land Speed Turbo build
Do they let you have an wideband/AFR meter on it?
- WickedWagens
Yes, you can data log, just nothing to control fuel or spark.
Top Speed 174.2 MPH
Top Speed 174.2 MPH
- petew
I guess the altitude at Bonneville makes tuning more interesting anyway right? Could you run much lower octane fuel and have less issues with going lean?
- Wally
Land Speed and turbo sounds like a great combination to me
Please keep at it. Pity you didn't got the EFI set-up going...
- WickedWagens
Yes, Hopefully the EFI turbo setup from the Ghia will make it into my VW 181 someday.
Top Speed 174.2 MPH
Top Speed 174.2 MPH
- WickedWagens
Checked all bearing clearances and started to assemble.
Top Speed 174.2 MPH
Top Speed 174.2 MPH
sweet, all go together smoothly?
- WickedWagens
Yes, Short block is complete. I'm just waiting for the cylinders from the machine shop and the new turbo from Shag.
Top Speed 174.2 MPH
Top Speed 174.2 MPH
- WickedWagens
I had Herbert Performance hone my cylinders to .006" piston to cylinder clearance and I set the ring gap to .023" top and .024" second.
long block done.
long block done.
Top Speed 174.2 MPH
Top Speed 174.2 MPH
- ToRy 70
Is that a base for a magneto? Never seen a dizzy like that. How will you control boost related timing? Cool project.
- WickedWagens
It's the base for the CB Magnaspark distributor.
Top Speed 174.2 MPH
Top Speed 174.2 MPH
- WickedWagens
It's in the car. Still some fabrication to do, but it's getting close. Little things now.
Top Speed 174.2 MPH
Top Speed 174.2 MPH
- rubenski
