FAQ:Water to Air Intercooler water pumps and more...
- panel
For those of you running a water to air intercooler.....what kind/brand/spec pump are you running? GPH etc.
-Are you running it continuous ? Or just activated at a certain temp?
-What size rad/condenser are you running? Fan on it?
-Are you also running a water tank as a reservoir or is there enough water in the system and just have a filler neck on the top of the intercooler itself?
-What kind/brand/size(core size) etc of water to air intercooler do you have? Barrel style or typical square/rectangle.
-What medium are you running? Straight water ? De ionized? Water wetter in there ? Antifreeze mix ?
- Chip Birks
Re: FAQ:Water to Air Intercooler water pumps and more...
Rule 1100gph in tank bilge pump.
Running a 3-4 gallon tank
Small 8 or 10 inch heat exchanger with 7 inch fan
Rectangle core 4"x10" with inlet and outlet on the same side. Chinese intercooler with cast end tanks.
I generally run water, but add a little rv antifreeze stuff in the winter.
Pump comes on based on throttle position or intake temp.
Bosch 1150(?) lph pump
Twin china ICs with 2 10x4,5x4,5" cores welded together
6 gallon water tank
3/5 water and rest with ice when racing
3/4" lines
no heat exchanger
pump on switch
6 gallon water tank
3/4" lines
no heat exchanger
pump on switch
2165cc on a Borg Warner S257 SXE, DTA S60 on E85.
Boost was created only to make people smile, and make power!
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
- risk
I also run the bosch pump, 1150 lph.. I believe it is used on the ford mustang cobra. (Pump wiring plug is the same as bosch injector plug)
Here: https://www.lingenfelter.com/product/BO ... FHefk2Wxdg
Homemade intercooler built from an eagle talon factory unit.
3 gallon tank in package tray - fill and burp system here.
3/4" lines, straight water (although a turbo buick buddy advises me to add a water wetter)
Heat exchanger is a Kawasaki Ninja radiator and aftermarket fan mounted under package tray.
Using the filler and cap from the same ninja (pressure relief-just incase).
Pump and fan runs constantly but will change if I ever upgrade to MS3.
- Kalle
Bosch 1150 lph pump
PWR PWI5881 5x6" barrel water to air intercooler
Custom made 6 gallon water tank mounted in the spare wheel well
Ice / Water mix and sometimes also dry ice
3/4" lines mounted under the car on each side
no radiator
water pump on switch
-K-
no radiator
-K-
- buguy
That's cool. It would be fun to try to figure out how to line a spare tire and use that as the water box. Stealthy!
- Chip Birks
- buguy
Where is your ECU if the tank is there?
- Chip Birks
- MarioVelotta
I used a PWR 4X10" Intercooler mounted on the inside of my package tray. I made some flanges on the firewall for the tubing to come through.
For the Pump, I used a Mercedes Auxiliary Water Pump - Bosch 0392022010. It is the same as the Lingenfelter pump with a Mercedes connector instead of the common delphi 2 pin. It flows 3.6gpm.
The tank was custom made by the same guy that built Chips (Dads Custom Tanks). I have a new much larger tank now with a big Rule Bilge pump inside. Unfortunately, now that I have a 6"X10" PWR intercooler it will no longer fit. So a 3rd tank will need to be built
Not pictured (yet) is the radiator or the intercooler. It is under the car mounted beneath the tranny.
The ECU controls the Intercooler pump, and the intercooler fan. They are staged to come on at temps about 10 degrees apart. The pump comes on first to get the water flowing and then the radiator fan comes on.
[email protected]
[email protected]
- buguy
That's a great use of wasted space back there. I just don't think I could bring myself to cut my car up. I'm struggling cutting off my apron!
- Chip Birks
Why not? Its your car. You aren't ruining it. If the next owner were to take my car, pull the go fast and sit low goodies out of it and put it all back to stock, thats fine. They might have a hole or 20 to patch. Its just metal though. Make it yours. Stop worrying about what the next owner will think when they buy it.
- buguy
Oh there will never be a next owner. My grandmother bought this car new in 65'. Well. At least not while I'm alive!
- rubenski
Came along this setup on facebook. Looks bitchin' to me!!
- V8Nate
I always wondered how that would work as efi with the injectors in the end castings and a single idf throttle body in the middle. poop you could even have the option for a 5th and 6th injector if needed for a little extra fuel:)
