Yes.
Here's mine.
- panel
Re: Here's mine.
What pump ?
- buguy
Re: Here's mine.
For me that was my least favorite part. I bet I still have 30,000 tiny holes in my fingers. It was also my first time working with it.
Re: Here's mine.
You guys and your bling.......
I'll take Gates FI hose and some FI clamps any day over that stuff.
- Chip Birks
Re: Here's mine.
,,I just over do everything. Realize I'm pulling two an8,,and one an10 full length lines,,two Mallory 140 pumps.Chip Birks wrote: ↑Sun Jul 14, 2019 8:41 pmCan't drag race at an NHRA track with that stuff though. Rules state less than 1 foot of rubber in the fuel system.
For a simple pump,an6 lines,,and more horsepower,,crazy.
Clonebug $100 total,, whole system,,,all funky fittings included.
That's cheap and NHRA approved.
- buguy
Re: Here's mine.
$100?! You did way better than me! I'm sure I had over $100 in just the Hose.
Re: Here's mine.
Howdy all,,apparantly I'm better today than I was 12 years ago when I first built this pile,,poop.
I relocated my fuel pump,,new mount,easier access for maintenance. Only concern,,I have 4" of clearance above tie rod. Only will be an issue on HEAVY compression after a wheelie.
Re: Here's mine.
Today was clutch break away test day.
Things have progressed to the point of actually putting the motor in the buggy.
A couple different "shim" sizes,,I'm right around where I need to be 160 to 175lb.
Re: Here's mine.
Mine slipped at 175 lbs...
You might want to bump that up to 250 ft lbs.
- Chip Birks
Re: Here's mine.
Stage 2, 4 puck "metal" disc .
- Chip Birks
Re: Here's mine.
Your puck will get meaner as it gets hot, unlike an organic disc. I wouldn't be tooooo worried about the number when cold.
