Another blow thru 1600 build
buguy
Re: Another blow thru 1600 build
Post by buguy » Fri Dec 27, 2019 10:27 pm
What duration @50 is your cam John?
andy198712
Post by andy198712 » Sat Dec 28, 2019 6:02 am
Being able to stick with single springs helps a lot with oil temp apparently, I’m happy with mine at .540 of lift
buguy
Post by buguy » Sat Dec 28, 2019 7:39 am
Ive never heard about it affecting temps before. Everything I have read says you need dual springs with anything over 460 lift. Also I had a very reputable VW builder with his own dyno and plenty of turbo builds tell me with my cam that has 430 lift... Well... Here is what he wrote:
"Wrt springs. Even with a milder cam you most likely can´t boost more than about 10 psi before the springs meet the limit. Any more than that and you will need dual springs. Another solution to gain a little more without machining is to buy a set of CB 650 springs and only use the outer spring along with a set of Ti retainers. That should give you room for approx 4 psi more."
I was surprised to say the least. Mine seems fine at 30 psi. Maybe it's not though??!!
andy198712
Post by andy198712 » Sat Dec 28, 2019 8:31 am
there's single springs and there's single springs though ;) mine are a bit fancy, that being said, when i start adding boost i will need to either shim them more or add an inner spring but i'm loathed to :(
madmike
Post by madmike » Sat Dec 28, 2019 8:43 am
Thing is you don't want 'Valve float 'as in valves bouncing off the seats :wink:
Do turbo your bug John, you'll like it :wink: :lol: I ask guys if they ever rode a 125cc-250cc 2 stroke newer MX Bike?,, same power band but in a car :lol:
woodsbuggy1
Post by woodsbuggy1 » Sat Dec 28, 2019 12:44 pm
Might want to take a look at beehive valve springs, they require no machine work (unless large cam lift) and are very lightweight. Dan Ruddock has them listed on the Samba for $220 plus shipping, I plan to try a set on next motor.
Kenric
Clonebug
Post by Clonebug » Sat Dec 28, 2019 1:44 pm
Beehives are gold.....or gold plated...... :shock: :lol:
I was going to go that route but at $270.00 plus shipping it was a little rich for my blood.
andy198712
Post by andy198712 » Sat Dec 28, 2019 1:46 pm
Have a look on stateside tuning’s website at their singles, that’s the ones I use :)
Not beehives but very cheap
buguy
Post by buguy » Sat Dec 28, 2019 3:09 pm
Yeah those beehives are pricey!
John S.
Post by John S. » Sat Dec 28, 2019 5:56 pm
I have on the shelf, CB Perf dual springs and CM retainers. I also have a Berg spring boss cutter.
madmike
Post by madmike » Sun Dec 29, 2019 6:46 am
8) cool I say ,"Git-er-Done" :lol:
John S.
Post by John S. » Tue Jan 21, 2020 10:14 am
So basically all vacuum lines need to tapped into the intake below the butterflies? As in the BOV, boost gauge, distributor and fuel regulator. Nothing in the carb hat?
Also, I was thinking of putting the fuel regulator in the front above the tank. Making a return line short and simple. I’ll already have vacuum up front for the boost gauge. ???
John S.
Post by John S. » Tue Jan 21, 2020 3:19 pm
My end castings don’t have a port. So, I was just going to tap the bottom of the vent mount manifold. Maybe two ports that “T” off.
buguy
Post by buguy » Tue Jan 21, 2020 3:40 pm
That's correct. Bout the only thing I remember putting before the butterfly was the wastegate and boost controller. I bought a vacuum manifold to run all mine. I ran one 3/8" vacuum hose to it and 1/4" off of it to all the stuff. I have 5 things that need a vacuum source though.
John S.
Post by John S. » Tue Jan 21, 2020 6:50 pm
I’ll be using the internal waste gate for. Plumber to the compressor.
