Hey guys I found this product on a water/meth injection site that I visit. It seems like a really cool diagnostic tool although a little spendy. Sure would be nice to know the knock threshold. They have several different models and priced accordingly
Check them out It seems like the real deal
http://tunernerd.com/
They also have a facebook page
https://www.facebook.com/groups/243740059840332/
And some info on them
Advanced Knock Detection
Why spend a fortune on knock detection hardware when you can have this instead?
See it in action or discover what makes this tool different.
We know how important knock detection is to you. We also know how expensive the tools can be. This is why we created Knock Monitor Pro!
How it works
Supplied easy to install data acquisition hardware monitors Knock vs RPM, Boost, AFR, Injector Duty Cycle
PC Software processes this information against a user set threshold, and engine geometry (bore size)
Software displays a chart showing when and where knock occured, if any – REAL TIME.
All logs are recorded, so you can replay sound and visuals.
Supported Vehicles
All fuel injected vehicles are supported
Features
Visual knock display
Detect inaudible detonation sound
Audible beep when knock occurs, useful for road tuning (optional)
listen raw or filtered engine sound
Sensitivity configurable
Configurable 5V inputs *
Save and replay recordings
View Logs and compare to EMS log
High precision
2 sensor input support **
Bore size to frequency
Adjustable frequency window
Adjustable threshold
Adjustable sensitivity
Designed for even the beginner
Save and load configurations
Future releases at no extra charge
Hardware updateable
Exportable datalog
** = Dual channel packages only
* = Except essential package
Tuner Nerd Knock detection
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Re: Tuner Nerd Knock detection
Interesting!
- slowsixtyduece
That is a pretty nifty tool and it's not too too expensive. I wonder if it is adjustable enough to compensate for the amount of noise our little motors make. The ACVW motor seems to have some loud parts (think clickety-clackity push rods) that could be mistaken for knock. Still if the software can isolate the knock this tool seems awesome.
- panel
These guys also run a good knock detector........
http://www.viatrack.ca/
Works with Megasquirt also.
Yes panel I have seen that one and it looks good. What I liked about the Tuner nerd is the recording and play back with head phones as well as the filtering and graphing so that the knock can be identified. Still looking into it I and have Emailed them
looks promising. He says it can detect Knock in a very noisy valve train
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
