Blow through 1776
Re: Blow through 1776
I gave up with DRLA boosting. You need a big float bowl vent or a tube from the vent directly into the boosted air flow AND CB mod rings.
Got my Walbro fuel pump, haven’t been able to install it yet, I want tio upgrade my fuel lines first, but in the mean time decided to swap my 28mm vents And 27mm mod rings with 34Mm vents and 33mm mods, now looks like I need bigger mains again
65 (I think) Baja 1776 turbo
Got my new lines. 8an from tank to pump, 6an from pump to regulator, 6an from regulator to carb.just waiting on CB to deliver the fitting for the bottom of my tank
Damn ,, -8 from the tank,, u can drive 10 miles with just whats in the fuel line
,,Old nascar trick HUGE fuel lines,, love it
- buguy
Is that a filter up in front of the pump?
Yes it is, and the -8 is only 8”
- buguy
Nothing wrong with that -8. Makes more sense to use what works with the fittings you have than beat yourself up using adaptors. Plus when you decide to build a big stroker and run E85 you might need all that volume!
I just wanted a safe and effective fuel line, since all the lines going from the front of the car to the back are full of garbage. I had to break up caked up dirt out of my throttle tube (thru the tunnel) then blow it out. Couldn’t even get a throttle cable through it. Same thing with the stock fuel line. Except it’s plugged up from front to rear still. Who knows how long it sat open to the elements before I bought it
Be watchful on the small filter if it has a nickel size screen ?, they are not big enough, plugs up quick
Thanks madmike, I’ll keep that in mind, the when I ordered the pump and filter it came with a wix filter with the push on hose fittings. I guess I could have gotten the an filter adapters, didn’t think of that
And for my next problem. The 15psi pump is too much for my regulator. Getting kind of frustrated here should I buy the CB turbo regulator for single carb?
pull the regulator apart and see if the Ball & spring are 'cocked' it happens
I think I’m just going to buy the aeromotive regulator. Pulled it apart and it was canted, put it back together and it still won’t regulate. Pegs my fuel pressure gauge almost immediately. At least with the aeromotuve I’d have a bypass back to tank. I’d hate to burn up that pump deadheading it because I want to save a buck.
Summit is super fast on delivery, aeromotive 13301 shipped and should be here tomorrow. My return line should be here next week... who was it that brought up EFI? I feel like I’m slowly getting there
