Cold weather = Less intake cooling needed?
buguy
Re: Cold weather = Less intake cooling needed?
Post by buguy » Sun Dec 13, 2020 5:48 pm
I was thinking something like dial-a-boost.
https://www.summitracing.com/parts/avm- ... dcQAvD_BwE
Clonebug
Post by Clonebug » Sun Dec 13, 2020 6:34 pm
Schweg wrote:
Sun Dec 13, 2020 5:29 pm
buguy wrote:Agreed. I do hope to do something like you for running regular fuel. There is only one place with it here and its kind of out of the way. It's not ideal to run E85 all the time. Last time i just used the laptop to turn the boost controller off but it would be nice to have a way to do it without having to drag the computer out to it.
Mine is definitely more of a toy than yours. I would never even consider driving mine the way you do. No a/c...heat....cruise... Actual working wipers... Etc.... Nope!
Funny that when i first came on here i thought you guys were nuts for spending that money on FI.
An electric boost controller wired to water meth system makes for a very simple low/high boost switching. Or just a switch for an electric boost controller gives you a two boost set up.
That's basically what I have.
One switch turns on and off the boost controller for either max boost or wastegate boost at 6.0 lbs. max.....the other switch turns on the water injection.
They both just interrupt the ground supply to cut them off.
I can run 6.0 lbs. boost without water injection or with since my Hobbes is set at 4 lbs. Sometimes I need cooling even at low boost...especially when it is really hot like in California....it's really a whole new tune......if I lived there.
Schweg
Post by Schweg » Sun Dec 13, 2020 7:20 pm
I have an AEM progressive controller so mine is off and 6lbs of waste gate or on and progressive water meth and 20lbs of boost, with water starting at 6lbs.
As for dial a boost it seems fun but I feel like your burning inputs to make it happen. Maybe just run boost by gear once you get a sensor in.
buguy
Post by buguy » Sun Dec 13, 2020 8:17 pm
I'm not 100% sure but i think the dial-a-boost would just go in line with the electronic controller. What i would be looking for is to control the amount of boost i get depending on my fuel. Although i may be able to control that by the ethanol %....i really don't know yet. Probably should add this topic to my thread so we don't muddy up the OP's original topic.
Post by Chip Birks » Tue Dec 15, 2020 9:50 pm
buguy wrote:
Sun Dec 13, 2020 12:42 pm
Interesting. I hadn't thought of what happens when ambient temp changes with W/I.
Thanks for rubbing in the fact that you don't have seasons in Floriduh. I've got 6 inches of snow in my yard right now 🤮
buguy
Post by buguy » Tue Dec 15, 2020 11:07 pm
Well it is going to dip down into the 60's here tonight! That's almost a season!
