Alright, little update. I placed my CB order yesterday with the following:
1.4 forged rockers
dual taper chromoly pushrods
28mm lightweight lifters (cam is a EP1 blank)
pushrod tubes and seals
straight cut cam gears
650 dual springs (just need to get something in hand so I can test and get some numbers, even if these don't work)
I believe I will have everything to bolt the long block together with the most recent order. Haven't heard from WebCam after placing my order, so I suspect they are experiencing the typical Covid delays.
Awesome Mike, thanks for the reassurance. The springs are really the last part of the whole build that I can't wrap my head around.
Figured I would NA the motor for a small break in period with just the outer springs, and then put the inside ones in when I hooked up the boost.
buguy wrote: ↑Fri Apr 09, 2021 1:55 pm
Can you do that?
Yeah, I have heard of several others doing it, so I figured it was acceptable. I didnt think of it myself by any means. I'll let you know what happens when I get there.
Well, my cam came in, and I immediately noticed it wasn't what I ordered
I wanted it to be on an EP12 blank and was going to run the CB Ultralight Weight Lifters (already in the mail) because I know they are compatible. I called WebCam when I made the order, so I have no invoice besides the one they sent in the mail with the cam itself. I'm hoping they take it back and send me the correct one, but having made the order over the phone, I'm skeptical.
Apparently this has been an issue for them lately. Rep I spoke with mentioned they don't even have any EP-12 blanks right now, but they'll send me one when they get it in...could be over a month before they get blanks in
